  • doktor101101 Friend
    #142468
    I love this template, but it is breaking in IE8.
    http://www.yournewwebsite.ca/hosting/coopersrv/
    If you view the above link in IE8 and Chrome, you’ll see the difference.
    Any ideas how to fix this?
    prakash Friend
    #309952
    Hi…there is a problem with JA Cooper displaying in IE8 and this issue has been raised and discussed by me in another post too…but till they fix it..i suggest you add a line to the index.php file inside the template that displays the site in IE8 Compatibility mode.
    mfcphil Friend
    #309963
    If it is a compatibility issue
    You need to paste code into the first line of the <head> of your index.php file
    <meta http-equiv=”X-UA-Compatible” content=”IE=7″ />
    although your site is showing errors
    <blockquote>Webpage error details
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB6; .NET CLR 1.0.3705; .NET CLR 1.1.4322; Media Center PC 4.0; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648)
    Timestamp: Sat, 4 Jul 2009 07:23:13 UTC
    Message: ‘this.descs[…].innerHTML’ is null or not an object
    Line: 127
    Char: 5
    Code: 0
    URI: http://www.yournewwebsite.ca/hosting/coopersrv/modules/mod_jaslideshow2/assets/ja.slideshow2.js</blockquote>
    doktor101101 Friend
    #310009
    Thank you, thank you. Problem solved.
    mayke Friend
    #310508
    Thanks mfcphil, it solved other templates too!
This topic contains 5 replies, has 4 voices, and was last updated by  mayke 15 years, 5 months ago.
