  • Richard A Friend
    #185177
    I was having problems with JA Countdown working, then not working, on the test site as I was trying out different combinations of modules and plug-ins.
    I went through from quickstart installation step by step and the problem is when System – JCK Modal plug-in is enabled. If I disable the plug-in, the JA Countdown module works again.
    The final part of JCK Editor installations state:
    “Once installed users wanting to use to the editor’s MooTools light-box feature are required to ‘Extensions’ > ‘Plug-in Manager’ and filter for ‘JCK Modal’ to enable the plug-in.”
    Is there any reason why I should keep this dsabled, or if not could you fix JA Countdown to work with JCK Modal enabled please?
    phong nam Friend
    #484365
    Hi dealthenuts,
    Can you send me a PM with your URL & admin account for further checking ? I’ll try to fix on your site.
    Regards,
    Leo
    Richard A Friend
    #484469
    Thank you, pm sent.
    phong nam Friend
    #484562
    Hi dealthenuts,
    I already check your site, there is no conflict between JCK Modal & JA Countdown. Acutally, Countdown module will appear just only when you use “Countdown-Page” style as default. In addition, on your server, Open templatesja_mitiustemplateDetails.xml. Then insert <position>countdown</position> line before </positions>. Pls see my snapshots for details:
    http://easycaptures.com/fs/uploaded/557/7079664535.png
    http://easycaptures.com/fs/uploaded/557/3724028899.png
    http://easycaptures.com/fs/uploaded/557/2729139368.png
    Regards,
    Leo
    Richard A Friend
    #484612
    Cheers Leo, thank you for your help!
This topic contains 5 replies, has 2 voices, and was last updated by  Richard A 11 years, 10 months ago.
