  • Tech-xml Friend
    #165873
    The problem is that the comment block is above the Block Author. How to display below this block?
    #399870
    Hi insofticursos,
    i checked in Ja travel quickstart and see comment block is under of author block, may be this is problem in css in your site, please send me url i will help you solve it.
    thanks
    Tech-xml Friend
    #400878
    Activate the plugin no more items in aperece K2.
    JaComents came installed with the same problem. Block comments above the pack is the author.
    Link: http://tinyurl.com/5wdou8p
    Tech-xml Friend
    #401036
    Please help me figure out why the Disqus plugin The Plugin Discussion Echo does not work on my site. Already tested in other templates and it worked well.
    Tech-xml Friend
    #401209
    Plugin error message:
    We were unable to load Disqus. For more information please see our documentation on identifier and urls.
    Link: http://tinyurl.com/6zrzk6a
    Tech-xml Friend
    #401348
    there are days when I am with this problem unresolved …>:(
    I want to know if there is already conflict in tample Travel?
    Because there are times that comment and others not apaerece
    For example the first time you access an item it appears K2. But if I give a refresh the page it simply vanishes.
This topic contains 6 replies, has 2 voices, and was last updated by  Tech-xml 13 years, 5 months ago.
