  • moreguinness Friend
    #179094
    Hi folks
    trying to add in a module in the position ‘body’ on the template, however the template position guide shows this position, i just cant seem to find it in the back end….probably something simple but i’d appreciate any advice I can find all other listed position except this one.
    regards
    j
    #461026
    Hi moreguinness,
    I don’t think there is a position name Body for this template, you can check out which positions were used for this template by visiting this url http://joomla16-templates.joomlart.com/ja_droid/?tp=1 or just added ?tp=1 at the end of your homepage url.
    Hope you got it !
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 12 years, 5 months ago.
