  • msudiva2 Friend
    #154931
    Hi, I just uploaded the jadroid template. I like some of the custom modules in the demo – how do I locate them in the module part of the admin control panel? I also need help for the search bar, and the footer.
    Is there a user guide for ja droid? This would be very beneficial to newbies.
    Thank you.
    aman204 Friend
    #357686
    Please view this::
    http://www.joomlart.com/forums/topic/ja-droid-module-position-guide/ >>> Outlays the module positions of specific template
    http://www.joomlart.com/forums/topic/ja-droid-userguide-old/
    Sub-topic mainly of interest::
    IV. Tips to create modules like our demo
    msudiva2 Friend
    #357816
    Hi Aman204, thanks for these suggestions.
    Okay, I have looked at the guide, I guess the problem is that the demo modules are not in the area where I can get to them on the control panel. Should I reinstall them using ftp?
    the website i’m working on is http://www.thebingmangroup.com
    I want to add a search bar, the footer, and the user1,user2, user3 portion like the demo (this is cool).
    Again, thank you all for your help. 🙂
    msudiva2 Friend
    #357823
    Hi Aman204,
    I had to take another look at the guide, I was able to get some of the things to work!!! 🙂 Thank you.
    Now, I am still having problems with the search bar, do you have advice on this one?
    Many thanks.
    aman204 Friend
    #357832
    <blockquote>Now, I am still having problems with the search bar, do you have advice on this one?</blockquote>
    Do you wish to setting up search module as seen in demo template? If yes, Please assign the joomla default search module to right position
    Also, for info, If you wish to replicate the demo template easily, Please use in quickstart package which can be downloaded from template download area
    Quickstart installation guide::
    http://www.joomlart.com/forums/topic/how-to-install-joomlart-quickstart/
This topic contains 5 replies, has 2 voices, and was last updated by  aman204 14 years, 3 months ago.
