  • lavian Friend
    #160650
    Uso il template Ja_Droid 1.6, ho installato l’estensione ja_bullettin, ma non riesco a trovare la posizione ja_tabs.
    Ho aggiunto 2 moduli Latest News e Most Read da visualizzare in posizione ja_tabs ma non sono visibili. Se li sposto in right si vedono, ma, senza l’effetto tabs.
    Come si aggiunge una nuova posizione al template, per esempio ja_tabs?
    Grazie
    #378396
    Dear lavian,
    kindly translate your post into english,i tried translate it myself but I am not much understand 🙂
    lavian Friend
    #378418
    <em>@lavian 223615 wrote:</em><blockquote>Uso il template Ja_Droid 1.6, ho installato l’estensione ja_bullettin, ma non riesco a trovare la posizione ja_tabs.
    Ho aggiunto 2 moduli Latest News e Most Read da visualizzare nel modulo Ja_bullettin in posizione ja_tabs ma non sono visibili. Se li sposto in right si vedono, ma, uno sopra e l’altro sotto, senza l’effetto tabs.
    Grazie</blockquote>
    Nessuno può aiutarmi?
    lavian Friend
    #378529
    Using the template Ja_Droid 1.6, I installed the extension ‘ja_bullettin’ but I can not find the location ja_tabs.
    I added 2 modules ‘Latest News’ and ‘Most Read’ to display in position ‘ja_tabs’, but they are not visible. This happens because the position does not exist. If I move two modules at the ‘right’ position, they are seen, but without the effect tabs.
    How do I add a new location to the template, for example ja_tabs?
    lavian Friend
    #378580
    Ok the translation?
    #378730
    Dear lavian,
    If you found the ja_tabs are missing you just need to enter that position into the position dropdown box when you edited or created a module.
    It is quite easy and I hope it helps.
    lavian Friend
    #378943
    <em>@dathq 224237 wrote:</em><blockquote>Dear lavian,
    It is quite easy and I hope it helps.</blockquote>
    The position ja-tabs in the template ja-droid, does not exist.
    I was wondering, how do I add a new position in a template?
    The plugin ja-tabs and activated. Ja-tabs in position (I am writing in module position) Insert the two modules, but are not visible, why? Perhaps because the position ja-tabs do not exist, and, it must create it.
    #378957
    Dear lavian,
    As I said in the Previous post,if you found a position is missing you just need to enter it right into the position dropdown box when you was editting a module.
    if the module position you inserted is ja-tabs then you need create a custom module,insert into it this content
    {jatabs type=”modules” animType=”animNone” position=”top” widthTabs=”120″ heightTabs=”auto” width=”100%” height=”auto” mouseType=”click” duration=”1000″ colors=”10″ module=”ja-tabs” }{/jatabs}
    Then assign it to the right position as you wanted
    I hope this would help !
    lavian Friend
    #379090
    Thanks! Thanks!
This topic contains 9 replies, has 2 voices, and was last updated by  lavian 13 years, 10 months ago.
