  • russh Friend
    #156529
    when I enable breadcrumbs on my site, the homepage doesn’t load…
    aman204 Friend
    #363197
    Can you please eloborate if you are getting some error or other problem?
    russh Friend
    #363291
    <em>@aman204 204009 wrote:</em><blockquote>Can you please eloborate if you are getting some error or other problem?</blockquote>
    Hmm, possibly a serious error… or maybe a permissions error? Here’s a snippet from the error log;
    PHP Warning:require_once(/home/website/docroot/modules/mod_breadcrumbs/helper.php) [<a href=’function.require-once’>function.require-once</a>]: failed to open stream: No such file or directory in /home/website/docroot/modules/mod_breadcrumbs/mod_breadcrumbs.php on line 18, referer: http://www.website.com/administrator/index.php?option=com_modules&client=0
    PHP Fatal error:require_once() [<a href=’function.require’>function.require</a>]: Failed opening required ‘/home/website/docroot/modules/mod_breadcrumbs/helper.php’ (include_path=’.:/usr/share/php:/usr/share/pear’) in /home/website/docroot/modules/mod_breadcrumbs/mod_breadcrumbs.php on line 18, referer: http://www.website.com/administrator/index.php?option=com_modules&client=0
    PHP Fatal error:spl_autoload() [<a href=’function.spl-autoload’>function.spl-autoload</a>]: Class JFactory could not be loaded in /home/website/docroot/libraries/joomla/session/storage/database.php on line 84, referer: http://www.website.com/administrator/index.php?option=com_modules&client=0
    aman204 Friend
    #363426
    Seems that error is relative to missing module files. Please try re-install specific folder with files intact from unzipped joomla files package::
    Ensure to take backup before doing so
This topic contains 4 replies, has 2 voices, and was last updated by  aman204 14 years, 1 month ago.
