Viewing 15 posts - 1 through 15 (of 18 total)
  • dgjoom Friend
    #173694
    Ja Elastica need help reduce gap
    Hi…i was try find to all css file to reduce gap between main body and modul, but after 6 hours i couldn’t find it.
    Im really need help to reduce the gap as picture illustration and how to add line under MAIN MENU
    still work on local host.
    Thank you for your kind attention
    1. ja_elastica
    Blaine Friend
    #437629
    Elastica is based on the jQuery Masonry Script.
    It is menat to be elastic and I think reading this article would help you to become more familiar with how it works.
    That said, it would be best to download and use FireBug to determine where the code is calling from.
    dgjoom Friend
    #437675
    Hi Blaine..
    Thanks for reply.
    I was using firebug and web developer but im still can’t find the code to reduce the gap :((.
    btw im still learning so I am not too familiar with the coding
    Blaine Friend
    #437779
    Can you provide me a link to the page as well as a screenshot showing exactly the gaps you are interested in please?
    dgjoom Friend
    #437806
    Hi.. Blaine,
    Thanks for post.
    I was inform on my first post (it still in local host)
    dgjoom Friend
    #437906
    Link deleted
    adcowebagency Friend
    #438162
    Hi dgjoom
    One solution I find for your problem is to remove the class “grid double” from your “ul” . I think you have custom html modules with the unordered lists. I tried that with Firebug on your site ant it works perfect at any screen viewport.
    Also you can solve your problem if you restore your layout css file with this code (line 80):
    “.ja-masonry .custom, .grid-double .custom, .grid-tripple .custom {
    width: auto;}
    dgjoom Friend
    #438175
    Hi adcowebagency,
    Thanks for post.
    Unfortunately the code that your mention is original css code, it comes with elastica template and i think there it is no problem with the code.
    As I know there is No custom html on the sample site, can you inform me which modul do you think it custom html?….
    Can you explain here more specific and detail?… so i can try it.
    <em>@adcowebagency 300375 wrote:</em><blockquote>Hi dgjoom
    width: auto;}</blockquote>
    Blaine Friend
    #438480
    djjoom,
    Please provide a screenie and circle where you wish the gap removed.
    I have Elastica loaded on a site and am ready to help you if I know where to begin to look in the code for the gap you mention.
    thanks!
    dgjoom Friend
    #438508
    Hi.. Blaine.
    Thanks for post.
    I was priveded the screenshot on my firs post, please to check it.
    Here in enclosed again
    Please check red line.
    1. Untitled
    Blaine Friend
    #438621
    You can go into module.css file and change padding (gap) there but it may be universal changes not just in specific areas.
    dgjoom Friend
    #438766
    Hi Blaine..
    I was try it and its nothing happen.
    Blaine Friend
    #438917
    And you have been sure to clear your site cache, T3cache (if applicable) and browser cache?
    Also, when you say didn’t work, were the changes live through edit or in the actual files?
    Blaine Friend
    #442216
    Hi!
    May I mark this one solved yet?
    Thanks!
    dgjoom Friend
    #442360
    Actually I didn’t found any solution till this time how to reduce it.
    But its depend on you, you can mark it solved or not.
    Im not get back to this forum cause i think you can’t give detail answered or solution, but its look I only got question.
    I think i was post my question with clear information, also i was post that I am not too familiar with the coding.
    I mean if you know exactly the solution it can be simple to inform here the file name should be changed, what code should change or use other code if need… etc
    eg this file “A” changed the code …bla…bla… with code… bla…bla…. change tho code on line 3 or 10 … etc
    But here i didn’t get it, so I think here is not the right place to solve the problem.
This topic contains 18 replies, has 4 voices, and was last updated by  Blaine 12 years, 10 months ago.
