Hi dgjoom,
The file you want is layout.css. As any changes are at your own risk, I’d suggest making a copy of this file so that you can restore if necessary.
At line 36 start all the Gutter settings. At line 57 you see this and this is probably where you should adjust first and see if it is how you like it.
#ja-main-wrap div.ja-moduletable-inner,#ja-main-wrap div.moduletable-inner,
#ja-main-wrap div.ja-module-inner,
#ja-main-wrap div.module-inner,
#ja-extra-col div.module-inner {
margin: 1em < Change this number either using em sizing or you can also use px e.g. 0.5em OR 5px
Does that help you?
Hi…swissa.
Thank you for your right answer!. This answer as I wanted as a beginner like me, detail and work, not a question.
Its working as i want.
For moderator you can mark this as solved.
This topic contains 18 replies, has 4 voices, and was last updated by Blaine 12 years, 10 months ago.
