November 20, 2017 at 8:17 pm #1075494
Hello, i have problem with modules DJ ( Classifieds, DJ League) and JULOA (Adsmanager) on JA Elastica. After publishing module destroying page layout. Look at image in attachment.
Best regards, Rafal
- This topic was modified 7 years, 1 month ago by mikedos.
Saguaros ModeratorSaguaros
November 21, 2017 at 4:45 am #1075580Hi Rafal,
How it goes when you use these modules in default Joomla template?
These are 3rd party extensions, you can share the info so we can check.
November 21, 2017 at 6:46 am #1075597Hello Saguaros
On protostar it’s ok. I sent info.
November 21, 2017 at 8:07 am #1075616It seems that the Adsmanager menu module causes the conflict with the masonry of template. Could you share the package of Adsmanager extension?
November 22, 2017 at 1:39 am #1075740I got it, I will check and get back to you.
November 24, 2017 at 7:32 am #1076405It due to the AdsManager component which loads jquery after the masonry so it caused the issue. You can try opening the file: /components/com_adsmanager/lib/core.php
Look for this line:
JuloaLib::loadJquery();
Replace it with:
$app = JFactory::getApplication(); if ($app->isAdmin()) { JuloaLib::loadJquery(); }
I attach this file so you can see the difference.
November 27, 2017 at 2:43 am #1076830Which part do you want to add image? article or module?
November 27, 2017 at 6:32 am #1076906Saguaros ModeratorSaguaros
November 28, 2017 at 8:34 am #1077306But which part should I edit to see as described in your screenshot? article or module?
November 29, 2017 at 6:20 am #1077597Saguaros ModeratorSaguaros
November 30, 2017 at 2:02 am #1077888Hi,
I try switching default template to a standard template of Joomla but see the same: http://prntscr.com/hh2ci9
Kindly check this Ads component again as it even has issue with default Joomla.
AuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 13 replies, has 2 voices, and was last updated by Saguaros 7 years, 1 month ago.
