  • jimmer Friend
    #134680
    Well, I am getting closer to the way I want the template layout…;)
    Thanks for everyones help so far.
    If you go to http://sportbikejunkies.net/Run4Youth you will see the main menu…Left side is out of alignment somewhat. How do I fix this?
    This should be the last request for help…:-[
    Thanks again,
    James
    mfcphil Friend
    #276606
    Go to the template.css file in templatesja_faguscss folder.
    and add the following code :
    ul.menu {
    ul.menu li {
    width: 99%;
    jimmer Friend
    #276616
    <em>@mfcphil 87495 wrote:</em><blockquote>Go to the template.css file in templatesja_faguscss folder.
    ul.menu {
    ul.menu li {
    width: 99%;
    </blockquote>
    Does it matter where?
    Thanks again mfcphil,
    James
    jimmer Friend
    #276618
    <em>@jimmer 87509 wrote:</em><blockquote>Does it matter where?
    James</blockquote>
    I posted at top of css and it worked…Thanks again,
    james:)
    mfcphil Friend
    #276626
    Great…good luck with your site and the run!!
This topic contains 5 replies, has 2 voices, and was last updated by  mfcphil 16 years, 1 month ago.
