JA Featured Articles problem in multiple language site
Forums Joomla Templates Club JA Teline IV JA Teline IV Solved Issues JA Featured Articles problem in multiple language site
That may be a real solution 🙂
I’ll let you know the result.
Unfortunately it does not work. I guess it is not related with font type also. Because it was working in the beginning properly.
Any other idea?
The problem is in firefox. In explorer it looks fine.
Hi again,
I checked the site in FF and IE8 and it seems to me that the font-family and font-weight getting applied in FF is not applied for IE8.. Can you check if you have any IE specific stylesheets in your template/css folder.. If you find any, please make sure that whatever styling is applied to the menu css / template css for menuitems, is same in the IE specific css..
1 user says Thank You to himangi for this useful post
I guess I made a mistake sorry…
well, I could not find any related code in the css and I decided to try your first solution. And it works. I’ve tried some different types of google fonts from cyrillic scripts and now there is not any problem. I guest in my first attempt, I was dealing with wrong menu. Sorry for stealing your time. And thank you…
Kind regards
Alper
This topic contains 21 replies, has 2 voices, and was last updated by bjeykua 13 years, 4 months ago.
