Viewing 1 post (of 1 total)
  • Hung Dinh Friend
    #158876
    JA Flowlist Module for Joomla! 2.5 Guide
    JA Flowlist loads external images with title and hyperlink from categories and ordered by setting and creates elegant 3D flow animation. JA Flowlist also allows you to show images from a folder in images folder of site root.
    Flexible parameter makes it easy to integrate this module into your web site. JA Flow List is the perfect module for displaying dynamic image sets.
    Step 1: Installation
    1. Install the module via Joomla Installer
    – If you are new to joomla, you can use our detailed guideline for installing module Module Installation Guide
    2. Enable the module
    After installing the module, to display the module on the front end, you must enable (publish) the module
    3. Assign position for module
    This function is to set the position for the module on the front end.
    Step 2: Configuration
    1. Global configuration
    From the back-end of your Joomla site (administration) select Extensions->Module Manger, then click on module named JA Flowlist to go to configuration panel
    Parameter explanation
    Title: Module title displayed on the front end
    Show Title: Show or Hide module Title on the front end
    Position: The position of the module displayed on the front end
    Status: Published or unpublished the module
    Access: Set accessibility for the module
    Ordering: Set the order of the module on the frond end
    Start Publishing: Set time for starting publishing
    Finish Publishing: Set time for finishing publishing
    Language: Set language for the module
    Note: user can write some useful information here
    ID: ID of the module
    Module Description: Display brief description of the module
    2. Set page to display the module
    This function is to set the page user want to display the module on.
    Parameter Explanation
    Module Assignment: List of type for choosing page to display the module (On all pages, No pages, Only on the pages selected, Only all pages except those selected)
    Menu Selection: List of Menu and all pages in a Menu
    3. Setting Content
    This function is to configure for the content displaying on the front end. Content Source can select from Joomla Content , Image folder or K2 Content.
    Here are 2 examples that can let you see the difference on front end when we have different configuration
    Example 1: Source From Joomla Content with “Featured” articles
    Example 1: Ordinate description Parameter setting
    Parameter Explanation:
    Flow list from: Select content source to display in module. This module supports Joomla Content , Image folder and K2 Content
    Select Categories : List of categories where articles are called.
    Featured Items : Including 3 function: Show, Hide or Show only featured articles
    Article Sort Order: Order articles by date or ordering
    Max Articles Display: Maximum number of articles to be displayed on the front-end
    Show Description Images: Select Yes/No to show/hide image title
    Ordinate description: Description of ordinate (input number)
    Text description style : color & font size of description (ex: color: #E66B2E; font-size: 20)
    4. Setting Display
    Setting Display is to configure for the displaying of flow on the front-end
    Frontend Appear :
    Flow Width: Width of flow list in pixel
    Flow Height: Height of flow list in pixel
    List Height: Height of list in pixel
    Flow Fade Space: Fade space of flow list (number)
    Background color: Background color of module (hecxa)
    Start Item: Possible to simultaneously load the StartItem from the flow list
    Animation Tween Type: Type of image animation tween
    Animation Speed: Speed of flow animation
    Slide Show Time: Set time in millisecond of slide show
    Auto play: Yes/no auto play flowlist
    [Image Padding: Set image padding on the front-end
    Angle: Angle of image
    Vertical: Vertical of image
    Reflection Setting Alpha : Set light for reflection
    Reflection Setting Clip Alpha : Set light for reflection clip
    Reflection distance: Space between root image & reflection
    Reflection matrix ratio: Reflection matrix ratio
    Reflection Setting Matrix Drop Off : Reflection Setting Matrix Drop Off
    Example:
    This example will show you the result of our displaying setting and the differences on the front-end when we have different configuration
    Example 1:
    Example 2:
    5. Image Setting
    Image setting is to configure for the displaying of article images on the front-end.
    For more details about image setting and thumbnail mode, click HERE
    6. Advanced Options
    This function is to set advanced options for this module
    – Caching: Use Cache/Don’t Cached option
    – Cache Time: in millisecond
    Check the live Demo for visual presentation.
    1. enable
This topic contains 1 reply, has 1 voice, and was last updated by  Hung Dinh 13 years, 11 months ago.
