Viewing 15 posts - 1 through 15 (of 22 total)
  • jonas37 Friend
    #118040
    JA header module doesn’t load in IE and turn webpage not accessible when used as flash.
    I know this module its new and not necessarily tested by everybody, any way… I’ve found strange no else mention it making me insecure about other’s possible reason to the problem in my website.
    However, when used the module as JavaScript or when unpublished the website works, so I think there is no more space for dough or look for other reason.
    There is out there someone with same problem and possible solution?
    What about in house solution?
    Thanks’ guys
    davidp Friend
    #213562
    <em>@jonas37 5403 wrote:</em><blockquote>JA header module doesn’t load in IE and turn webpage not accessible when used as flash.
    Thanks’ guys</blockquote>
    I’ve just begun to experience the same problems with JA_Antares. When loading the page in IE, I get the error: “Internet explorer cannot open the page http://www.mysite.com” with “Operation aborted”.
    This happens sporadically with half the page loading, a quarter loading etc.
    If anyone has a solution, I will be very grateful!
    Khanh Le Moderator
    #213623
    Could you provide your live site url. I haven’t faced this problem yet, I need you live site to explore and find the solution.
    davidp Friend
    #213641
    <em>@khanh 6837 wrote:</em><blockquote>Could you provide your live site url. I haven’t faced this problem yet, I need you live site to explore and find the solution.</blockquote>
    Sure thing, it’s: http://www.wccsworldwide.com/home
    This is a temporary url – so it will not be active within a few days. It will ultimately reside at http://www.wccsworldwide.com (hence, http://www.wccsworldwide.com has been used in my member area domain list)
    davidp Friend
    #213642
    I’ve just checked again, and have found that I receive the same error. To view the problem, please look at this image: http://www.wccsworldwide.com/error.JPG
    Also, just one quick piece of info that might prove useful to finding a solution: If I change the JA Header Module settings from “Flash Slideshow” to “Javascript Fade Slideshow“, it works! So it must be something to do with this?
    Many thanks!
    David
    davidp Friend
    #213786
    Hi khanh,
    I hope this is not too forward or presumptious… but I was wondering if you may have figured out a solution to this problem?
    Many thanks,
    David
    Hung Dinh Friend
    #213792
    Hi David,
    Could you PM me the admin login so that I can check it out for you?
    mixx Friend
    #213951
    I am having this problem in Safari despite switching over to JS from Flash. I read in another thread that the Safari issue had been cleared up. I am still getting submenu overlap.
    see: http://test.harbingerfdn.ca and use Safari…
    please help ASAP.
    mixx
    talleyrand Friend
    #214663
    If you set the JA header to use flash instead of Javascript and try to access your site with a browser without the flash plug-in, you get an error. I tried to use Javascript instead, I’ve no error, but nothing is displayed :http://www.saint-louis-marie-galante.fr
    Thx for any help
    Luc
    Tirrawarra Friend
    #214681
    <em>@talleyrand 8244 wrote:</em><blockquote>Hello,
    Thx for any help
    Luc</blockquote>
    I have just installed the new JA_Wistery and experience the same problems in Firefox – the header wont display in either the flash or javascript options – but it all works on another PC so the problem is probably local to the pc.
    hleen Friend
    #215360
    Same problem:
    JA Villadi & IE6
    Site unusable when using flash…
    Message is:
    “Internet Explorer cannot open the internetsite http://subdomain.mysite.nl/index.php.”
    “Operation aborted”
    Firefox has no problems…
    Han Leentvaar
    Paying member of the template club >:(
    balticfurniture Friend
    #227905
    I got the same problem with ja header module in flash mode!
    Internet Explorer cannot open the Internet Website http://www.balticfurniture.co.uk/.
    Operation Aborted!
    please, can you give any advise, how to sort it out?
    I found some info on:
    http://www.eoghanobrien.com/article/32/ie-operation-aborted
    benclay413 Friend
    #270000
    Any resolution to this? I see no pictures (but not the “files not found” error) in JA Villadi in Firefox, and the Flash version crashes IE. No images in Javascript IE.
    frogman Friend
    #281651
    A year and three months later and still no resolution?
    Ja Header Module still causes an “operation aborted” error in Internet Exploder. Granted it isn’t the greatest of browsers but still it does still have 80% or so of the browsing market. This would seem top priority. Yes javascript works, but why include the flash component at all when it doesn’t work?
    frogman Friend
    #281839
    Any workarounds?
    Also when using javascript fade slideshow the “Timer” setting seems to have little effect…
This topic contains 22 replies, has 12 voices, and was last updated by  jimgill 15 years, 12 months ago.
