Same problem with me.
http://www.warontheeasternfront.com
Internet explorer error.
Something to do with JA Header
I’ve got it working in Javascript but as you say it means the timer doesn’t work, which sux and taints the look and feel.
Also the images are skewed.
Meh…
Any resolution on this?
Not as far as I’ve found. Not a peep of a response either. This certainly does not add to joomlart’s otherwise good reputation.
Well I found that by changing the way the plugin multithumb shows images, had an effect. Before I had it using flash. Now I have to so that it shows images in a new window. It’s not as good but at least I can have JA header using flash instead of java script…
So that puts a plug in that problem…
How did you change multithumb thingy? Specifically. Not everyone can read minds…
oh i thought you could.
it’s in the plugin for multithumb. It has a box which you can change the way it displays the image when you click on it.
In Popup method: I now have it to Normal Popup from Slimbox
I don’t have a multithumb plugin.
<em>@frogman 106137 wrote:</em><blockquote>I don’t have a multithumb plugin.</blockquote>
yep i suspect everyone will have a different reason for this issue…hence the difficulty in solving it
This topic contains 22 replies, has 12 voices, and was last updated by jimgill 15 years, 11 months ago.
