February 5, 2007 at 5:17 am #118652
Hi i can not change the time between imag transitions
Can anyone help?
Åge:)
ErikThorsen FriendErikThorsen
- December 2005
- 10 times in 1 posts
February 5, 2007 at 7:15 am #214100What have you tried to do so far Ågebror? Have you played with the settings? What settings have you used?
February 5, 2007 at 12:24 pm #214110Hi
I have tried changing the time between the transitions of the pictures and have tried many values from 5 that is the standard up too 100 but the time between each change of pictur is the sameFebruary 5, 2007 at 2:04 pm #214116Same problem here as well
February 18, 2007 at 8:13 pm #214744I, too, am seeing the same issue. Transitions and times between pictures do not appear to be controlled thru settings. Would like to slow… things down, a bit. Otherwise, a great module.
February 22, 2007 at 8:57 pm #214879Same issue here, not enough time to read 2 sentences on an image. Help would be appreciated.
February 23, 2007 at 12:37 am #214884Ive noticed the same aswell when I have the JA header working in Java, but as soon as I configured it to work as Flash it works great,
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
February 23, 2007 at 2:59 am #214891You should try to change the setting for Timer and Fadetime paramenters.
February 24, 2007 at 3:18 pm #214953Hi,
Thank you for the response, it does work. Increasing Fadetime from 1 to 5 slowed the rotation to the desired speed. Kind of counter intuitive, though.However, please note that the speed of fading did not change and that changing theTimer variable does not seem to have any effect.
Also, although it does not really matter to me as JS is my preference, be advised that when switching to Flash the module stops working – and I do have the flash plugin installed in my browsers…
Best,
GM -
This topic contains 9 replies, has 7 voices, and was last updated by gmontagner 17 years, 9 months ago.
