  • Manos Moderator
    #156983
    Well i have try to validate Teline III v2 and ….i manage to do this except when i have ja_headlines module on….
    I am getting this error
    Sorry, I am unable to validate this document because on line 179 it contained one or more bytes that I cannot interpret as utf-8 (in other words, the bytes found are not valid values in the specified Character Encoding). Please check both the content of the file and the character encoding indication.
    The error was: utf8 “xCF” does not map to Unicode
    If i turn this module off then my main page – validates -> <http://validator.w3.org/check?uri=http%3A%2F%2Fwww.istories.gr%2F&gt;
    Any suggestions?
    Manos Moderator
    #365437
    Hi! i am the only one that faces this problem ?
    #365489
    Dear pascm,
    Can you post your url here for checking? I checked the teline iii demo http://templates.joomlart.com/ja_teline_iii_v2/ but I did not see the problem.
This topic contains 3 replies, has 2 voices, and was last updated by  Sherlock 13 years, 11 months ago.
