  • linkarea2012 Friend
    #1094654
    I want to change the color in the header bar. In which file do I have to change the color?
    I ask for help, thank you
    • This topic was modified 6 years, 9 months ago by  linkarea2012.
    You can use this custom CSS code:
    .t3-header {
      background: #4c95ec; /*change to your desired color*/
    put into the file: root/templates/ja_intranet (your default template)/css/custom.css (create this file if it doesn’t exist)
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 6 years, 9 months ago.
