  • monimono Friend
    #184428
    hi
    i installed the ja k2 filter from http://www.joomlart.com/forums/downloads.php?do=cat&id=20372 on joomla 3
    the plugin K2 – JA K2 Filter is enabled.
    i publish the module in position.
    when i clicking the Update Indexing at the main component i get the message “Does not exists extrafields indexing”
    and the module not displaying the extra field data.
    what do i missing?
    thanks.
    MoonSailor Friend
    #481268
    HI monimono,
    Have you created any extra field and added it to K2 item?
    <blockquote>
    “Does not exist extrafields indexing”
    </blockquote>
    This message means there is no extrafield created or not be assigned to any category. Please check again
    monimono Friend
    #481335
    hi
    we really need a solution for ja k2 filter in joomla 3.
    please help.
    thanks.
    MoonSailor Friend
    #481341
    Please check my above reply.
    monimono Friend
    #481367
    Hi Moon Sailor
    yes i created extra field group and assign it to k2 category and i can see it on the item pages at the bottom of the page (bicycle and company)
    http://82.166.184.77/~israelbm/index.php/shop/item/3-kink-curb-3
    thanks
    MoonSailor Friend
    #481481
    Hi monimono,
    I need a closer look to check this problem , please pm me admin account of your site.
    monimono Friend
    #481546
    Hi Moon Sailor.
    everything is working fine.
    thanks allot for your good will.
    have a nice day.
    commedia Friend
    #490436
    Hi there…i have the same problem, “Does not exists extrafields indexing”. I have created the extra field, i have assigned them to a category…can you help me please?
    best regards
    commedia Friend
    #490799
    Someone can help me please?
    MoonSailor Friend
    #490817
    Hi commedia,
    I need more time for checking. Pls waiting.
    HeR0 Friend
    #492981
    Hi There,
    I am happy to let you know that this issue will be fixed in coming release. Pls wait for a while.
    However, you can use the attached file to update this file: modulesmod_jak2filterelementsk2extrafield.php and if it does not help, pls feel free get back to me then i will help you.
    1. k2extrafield.zip
This topic contains 11 replies, has 4 voices, and was last updated by  HeR0 11 years, 7 months ago.
