  • palos Friend
    #1074044
    It was working for a year or so but clients just told me that it does not works weeks ago.
    palos Friend
    #1074045
    Luna Garden Moderator
    #1074378
    Did you upgrade JA K2 Filter & JA Directory to latest version ?
    Recently we just update some elements on JA K2 Filter, and JA Directory must be update also.
    palos Friend
    #1074523
    HI Luna Garden!
    I think JA K2 Filter is fresh…
    But JA Directory is still 1.0.5 because it contains a lot of solved error and override.
    The JoomlArt Extensions Manager FILE COMPARISON BETWEEN "JA_DIRECTORY" VERSION 1.0.5 AND 1.0.6 shows many Modified and Conflicted files but most of them is not true. Some of them done by me (and JA staff) but the others claimed conflicted/modified faulty as usual with this comparision.
    Therefore it is not a quick job to update it as I have to check the differences manually.
    Telling the truth it was working for months after the modifications but gone bad after some JA or Joomla updates. 🙁
    1. JA_k2_filter_screenshot
    #1074640
    In JA K2 Filter 1.2.9, we add more new features, and there will be some change on the layout.
    JA Directory has overridden the layout of Module JA K2 Filter, that’s why you must upgrade JA Directory to latest version to make it compatible with new JA K2 Filter.
    Or else, download JA Directory package: https://www.joomlart.com/downloads/joomla-templates/ja-directory/ by this link. Extract, copy folder html/mod_jak2filter to your template folder, and check if it works.
This topic contains 4 replies, has 2 voices, and was last updated by  Luna Garden 7 years ago.
