  • Mo0nlight Moderator
    #1012045
    You can share your site’s URL and admin account, I will check for you.
    fabiojordan Friend
    #1012254
    Mo0nlight Moderator
    #1012414
    Hi.
    It’s like you said.
    Config at your site right now is :
    max_input_vars 1000 1000
    And the input in the module shows up now is about 2000. So you need to set it to higher than 2000 to save the module.
    1. Screen-Shot-2017-02-21-at-2.20.41-PM
    fabiojordan Friend
    #1012585
    Hi there.
    That’s very strange. I change it on php.ini, and the option is showing in the cpanel. Is there any other file that I should edit?
    Thanks again!
    Mo0nlight Moderator
    #1012695
    Making change in that file is enough, you may need to reset apache take the affect of change.
    Then you can check in Administrator Panel > System > System Information > PHP information and see your configuration is changed or not.
    fabiojordan Friend
    #1012932
    Hi, Mo0nlight.
    I want to share that everything is working fine now. What happens is what follows:
    1) I changed the value of max vars in php.ini (in the home folder);
    2) But Joomla was taking values from php.ini in another folder (/opt);
    3) It was doing this way, because my htacess was pointing to that directory, because it was using PHP 7.0 by this setting;
    4) So, my host made the change to PHP 7.0 once and for all;
    5) I removed the settings in htacess and now its reading php.ini in home directory.
    Long way, but its working perfectly now.
    Thanks again and please mark the topic as solved!
This topic contains 6 replies, has 2 voices, and was last updated by  fabiojordan 7 years, 9 months ago.
The topic ‘JA K2 Filter Module dont save data – max_input_vars at 5000’ is closed to new replies.
