  • YitzySvei Friend
    #118131
    My problem is that when ever I add anything to the main menu it shows on the left side menu and the top ,but I just want to add things to the side menu and NOT to the top menu.How do I do this?
    itguy Friend
    #212865
    This is because both are displaying the main menu. Remove the main menu from the side column and then either create a new menu to use on the left or use the “other menu” there.
This topic contains 2 replies, has 2 voices, and was last updated by  itguy 17 years, 11 months ago.
