It will basically require your creating new image files for the areas where you want “white” – or, actually, simply removing/replacing the CSS parameters that are displaying the colors you do not want.
For the background image, it’s a simple matter of changing the CSS rule controling the background image – I believe it’s at line 25 (or so) in the template.css.css . .
body#bd {
color: #403C3A;
background: #E1D8C3;
If I’m not mistaken, this is the default for the “orange” color scheme. Try changing the background to #FFFFFF and see what happens. (Bear in mind, there are also corresponding “shadow” images found within the “wrapper” CSS rules. Depending on which of the three color schemes is selected, the corresponding “shadow” image is used. If you change your background to “white,” you will likley need to create two new “shadow” images … otherwise, you will have a bit of a color hue on your site margins against the white background.
#ja-wrapper2 {
padding-right: 14px;
background: url(../images/shadow-right.gif) repeat-y right #FFFFFF;
#ja-wrapper3 {
padding-left: 14px;
background: url(../images/shadow-left.gif) repeat-y left;
overflow: hidden;
Hope that makes sense. As always, trial-and-error experimentation can result in wonders.
TOM
