  • alexookah Friend
    #151249
    I used the Ja lime with quickstart and i had problem with encoding… when using some greek names to make my site in greek
    i looked in the mysql database and some components are:
    utf8_general_ci and other latin1_swedish_ci
    the latin_swedish_ci encoding of my database caused me problem when trying to change the mainmenu into greek.
    “Home” changed and it showed up as ??????
    i will now use the fresh install from joomla and then just the template and manually add some plugins.
    I say this in order to be fixed for other members of joomlart not having problem with quickstart.
    Dear alexookah!
    With your case, think that you should change the charset for all tables having the problem via the tools of phpmyadmin.
    alexookah Friend
    #344540
    <em>@tienhc 179753 wrote:</em><blockquote>Dear alexookah!
    With your case, think that you should change the charset for all tables having the problem via the tools of phpmyadmin.</blockquote>
    what do you mean?
    how is this possible to change the tables encoding?
    As the pics you put at topic #1
    You choose click the Structure button () in a row and the “Action” column, to view structure of table. In the Structure Table Page, you ‘ll see the Operations button , after clicked you ‘ll a form and you find the “Collation” field, you change charset in there
    Good luck
    alexookah Friend
    #348007
    yeah but this is really frustating..
    You should on the next update of ja lime fix this encoding issue
    thank you
    ok, i ‘ll fix if have bugs:)
    alexookah Friend
    #348308
    There are bugs
    Check this post:
    http://www.joomlart.com/forums/showthread.php?p=184036#post184036
    It’s time for an update of ja lime 🙂
    candostu Friend
    #348423
    I also have the same problem i need the quickstart but it doesn`t work, is there something new?
    perhaps can someone send me a working quickstart? thanks a lot
    thanks all, i create an issue in the PM, our developers check this issue in detail http://pm.joomlart.com/browse/JATCLIME-64
    korely Friend
    #350740
    I have the same problem with encoding (it does not perform polish letters – Ä…,Ä™,Å›,ć – etc.). I’ve changed everything by my on hands at phpmyadmin to utf8_general_ci, but it doesn’t help.
    When I install joomla 1.5.20 and afterwards install the ja lime template, thing works out, but I would like to have quickstart without this problem 🙂
    yes, i make sure that ‘s bug of database’s chatset! with some special case, i need to check this more detail
This topic contains 11 replies, has 4 voices, and was last updated by  Saguaros 14 years, 4 months ago.
