I changed from the Protostar template to JA Mendozite. I can make the website to be multi-languag by below method
with Protostar.
http://www.templatemonster.com/help/joomla-3-x-configuration-multilanguage-site.html
Because I could not install the template Mendozite directly to the original Joomla localhost, I used a quick start to open a totally new website in localhost.
But, I got a problem with Mendozite when I want to change it to be multi-language. The main menu is not changed
when I switch the language. They are all the same time the original menu. However, I can find the breadcrumbs map
changed. The main menu module is already unpublished, while the other two languages main menu is published.
Thanks for the time to help in advance.
