sfpkent Friend
sfpkent
- October 2008
- 75 times in 1 posts
November 13, 2009 at 7:25 am #145995Hi,
Good day! 🙂
I wish someone can help me on this. I have installed xmap for my site map, but once I viewed my site map, what typed in menu all come out.
Here is the link:
http://nsvision.com.my/index.php?option=com_xmap&sitemap=1&Itemid=82Anyway to maintain the menu wording and not appear on site map?
Thanks!
Kent
prakash Friendprakash
- October 2008
- 146 times in 115 posts
November 13, 2009 at 10:47 am #323479This I feel would be an integration issue between the JA Mega Menu and XMAP.
I think JA will need to release a patch for this or may be XMAP because XMAP simply takes wordings from the menu name…and what ever is there would be displayed. Hence JA will need to supply XMAP the format and a patch for sites running on MegaMenu would need to be applied for it to function correctly.I have already updated this post as a bug query and let us wait for JA to update this.
- 2008 times in 1700 posts
November 17, 2009 at 7:01 am #323881<em>@sfpkent 152707 wrote:</em><blockquote>Hi,
Good day! 🙂
Here is the link:
Thanks!
Kent</blockquote>Hi sfpkent
Please go to http://support.joomlart.com, submit a ticket, send us your live url, admin account ftp accocunt, so that we have a closer look on the issue.
1 user says Thank You to JA Developer for this useful post
sfpkent Friendsfpkent
- October 2008
November 18, 2009 at 9:43 am #324089Thanks, problem solved by JA Team. 🙂
- 1334 times in 848 posts
November 22, 2009 at 6:13 pm #324602Attached herewith is the modified xmap.html.php file. Others with similar problems might find this useful.
Arvind
- October 2008
November 22, 2009 at 6:53 pm #324608Thanks drarvindc! 🙂
November 22, 2009 at 7:19 pm #324611Thanks to JA Developer and his team. I just posted the file. They are the one, who fixed it.
Arvind
- October 2008
November 25, 2009 at 6:57 am #324882Hi, You can also check out this fix that I have posted
http://www.joomlart.com/forums/topic/integration-of-xmap-with-ja-mega-menu/
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 4 voices, and was last updated by prakash 14 years, 11 months ago.
JA Menu and Site Map problem
