  • petero Friend
    #175019
    http://talesfromthesea.net/index.php/en/book/bookings
    The top menu ( account details & search) is not selectable . I am using JAMethys. Do you know what I should edit in the template to solve this?
    Please update this thread with your account details for the backend or send me it via PM
    I can select the top menu but links are wrong “http://talesfromthesea.net/index.php/en/book/bookings#”
    petero Friend
    #443799
    The problem is the login menu located at very top does not respond here:
    So I have had to change the Methys template to Beez to enable the login to work as here:
    I have checked your site and seen that you are using joomla 2.5.2 but all your modules plugins and template are very old versions
    example: you have the T3 framework plugin version n. 1.3.1 the 1.3.2 was released in August 2011 the last is 2.5.1
    you need to update all to the last version template included ( you have the 1.2.0 version, after this joomlart has released other three version ) the last is 2.5.0
    Before you start the upgrade take first a backup of your site with the Akeeba component
    petero Friend
    #443853
    Dear Pavit
    updated to 2.5.1 T3 and Methys template, plugins, components; but getting a fatal error
    “Fatal error: Cannot redeclare class Browser in /home/expatsi1/public_html/stormpetrel.net/IFCM/plugins/system/jat3/jat3/core/libs/Browser.php on line 135”
    Please advise.
    Peter
    I cannot login with the previous account
    anyway try to uninstall and reinstall the T3 framework plugin
    petero Friend
    #443884
    Pavit – re-installed and now working
    Many thanks – but can you help with the original query I posted?: the top login menu on http://talesfromthesea.net/index.php/en/book which is visible but not selectable. I think it must be related to the very top position template
    Peter
This topic contains 7 replies, has 2 voices, and was last updated by  petero 12 years, 9 months ago.
