October 16, 2016 at 6:38 am #976759pavit Moderator
October 16, 2016 at 6:57 am #976773October 16, 2016 at 3:24 pm #976820This reply has been marked as private.pavit Moderatorpavit
October 16, 2016 at 4:39 pm #976838Hi there
I installe content – captcha plugin and now your re-captcha is showing , unfortunately it cannot be changed due to the fact that is a google script.
October 16, 2016 at 4:49 pm #976841Thank you very much,
I wish that the form fields is blue.
Thks
October 16, 2016 at 4:50 pm #976842This reply has been marked as private.pavit Moderatorpavit
October 16, 2016 at 5:27 pm #976855I wish that the form fields is blue.
It is blue now
To make other changes edit this css file /templates/ja_onepage/css/themes/modern/mod_jaquickcontact.css
October 17, 2016 at 5:46 pm #977228This reply has been marked as private.pavit Moderatorpavit
October 17, 2016 at 6:18 pm #977240Hi there
I forwarded your request to joomlart developers to have a look at it , please be patient until they debug the issue.
Regards.
Saguaros ModeratorSaguaros
October 18, 2016 at 3:00 am #977382Hi @congreso.ead
I check the override of JA Quick Contact module on your site and find out that it doesn’t generate class for styles selected in backend settings of module. I’ve updated this file: ROOT/templates/ja_onepage/html/mod_jaquickcontact/default.php
Line 21:
<div id="<?php echo $params->get('class_suffix','')?>ja-form" class="<?php echo $params->get('jastyle','style1'); ?>">
You can select the style now.
For the blue color of the form, as I can see that you already have style in ‘custom.css’ file, let me know if you need further helps on this.
November 15, 2016 at 3:17 am #986375Hi, I’m having the same.. I look everywhere but I can find the Multi Captcha Engine Plugin for J3.x, I re-download again all the files from the template and I don’t see it.
help please.
November 17, 2016 at 2:22 am #987121Hi,
You can provide the credentials of your site: URL, Admin & FTP account via your reply and flag it as PRIVATE reply so I will check for you.
italpascal Frienditalpascal
- November 2014
- 3 times in 1 posts
November 20, 2016 at 1:45 pm #987816you can have the links for plugin Multi Capcha Engine Plugin for J3.x ???
I can not findthank you
Ital Pascal
November 21, 2016 at 4:46 am #988016It goes with JA Quick Contact module which requires JAEC club membership to download: https://www.joomlart.com/downloads/joomla-extensions/ja-quick-contact-module/
April 20, 2017 at 2:38 pm #1027764Does that mean, that I can’t use the JA Quick Contact module with the OnePage Template anymore? Because I have the same issue like concreso.ead six month ago 🙁
Regards.
AuthorPostsThis topic contains 18 replies, has 6 voices, and was last updated by congreso.ead 7 years, 7 months ago.
