This topic contains 18 replies, has 6 voices, and was last updated by congreso.ead 7 years, 7 months ago.
The JA Quick Contact module is still available in JA Onepage template download package. You can access and download this module. And try with my above solution and let me know if there is any problem
thanks for your answer. I got the JA Quick Contact module and tried to use it, but the Multi Captcha Engine Plugin seems to be missing. And I don’t have a JAEC club membership to download it. Isn’t it possible to use the JA Quick Contact w/o this Multi Captcha Engine Plugin? Or can you pls add it to the JA Onepage template so it’s working with the standard contact form?
Regards.
I’m still in great want for a working JA Quick Contact module in JA Onepage template. Any ideas?
Regards.
