  • empire Friend
    #133413
    I am trying to get the JA Newsflash working on my site but am having problems with the way it is displaying.
    I have 3 articles that are set to display 2 of them have no images in the article yet but the 3rd I have put a image in the article it has 2 problems.
    1. The image only shows up on the first rotation after a refresh after that the image url seems to change then I get no image?
    2. The article with the image is changing the formatting, the Title of the article is now below the article contents, and the contents have lost their formatting?
    You can see the here.
    #270937
    Hi empire !
    Please send admin acc via pm , i will check it for you !
    goyat Friend
    #271568
    There is something wrong with JA Newsflash display. I followed the guide but no avail. :confused:
    Please see here
    I replaced JA Newsflash with May 2007 1.0 version and See what! It is working. I think JA should look into the current JA Newsflash version.
    #271618
    Hi goyat !
    What happen do you use Ja newsflash ?
    goyat Friend
    #271623
    I replaced the most recent JA Newsflash module with JA Newsflash May 2007 1.0 version . That solves the problem. I do not understand why the most current one is not working.
    eak099 Friend
    #272379
    Hi all
    How to fix this problem.
    When i test on localhost (apache) it OK but when i upload to Hosting and install it have same problem. any one can tell me how to solve this problem.
    Thk.
    #272600
    HI eak099 !
    Please send url of your site!
    eak099 Friend
    #272618
    eak099 Friend
    #272842
    <em>@eak099 82458 wrote:</em><blockquote>This is my site
    http://www.lovemelovemyweb.com/</blockquote>
    I solved that problem by myself
    by edit this file “ja-newsflashloader.php” file location
    -> modules/mod_janewsflash/ja_newsflash/ja-newsflashloader.php
    When open php file i add php comment “//” online 191
    <blockquote>
    if (substr($img, 0, 4) != ‘http’) {
    // $imgurl = defined(‘_LIVE_URL_’) ? (_LIVE_URL_ . $imgurl):(JURI::base().$imgurl);
    </blockquote>
    I don’t know for reason don’t ask for “WHY” but it “OK” for mysite 😉
    May have someone can explain ……. :confused:
    jimesten Friend
    #273860
    I am having the exact same problem, except your fix does nothing for me.
    Acutally, It breaks the newsflash entirely. Now it doesn’t cycle at all.
    NOT SOLVED!
    #273919
    Hi jimesten !
    i still need to detect the problem , please send me url of your site , i want to look into the problem.
This topic contains 11 replies, has 5 voices, and was last updated by  Sherlock 16 years, 3 months ago.
