  • hzc0mm Friend
    #161000
    1. JA News 2 module does not order the sections according to backend “Section IDs” ordering. Section IDs 20,19,30,18,21,22 come out as 18,20,19,30,21,22. So a wild mix of ASC and the order I entered into the backend. This MUST work!
    2. Search Site Link has some weird characters in the URL: It shows as “http://hotelmagazin-online.com/de/suchen/%252F” instead of “http://hotelmagazin-online.com/de/suchen/”. WTF?
    3. Some modules cannot coexist in the same tab, e.g. “Rok Weather” and the currency converter module i downloaded and some “most read” module. Had to order them vertically instead of putting them into one and the same JA_Tab. Sucks real bad.
    Please help!!!
    hzc0mm Friend
    #379874
    hmm… anyone?
    => i found that your module is old version, please get the latest version to upgrade for module, the issue is resolved.
    => This link was converted by the search component, i have not got any ideas
    => please follow to this guide to get both modules loading inside the tab http://www.joomlart.com/forums/topic/ja-tabs-userguide/
    hzc0mm Friend
    #380067
    Well, now the section ordering is working – Thank You!
    But: As you can see on the site, there are empty news containers (see: “Europe”) – why’s that?
    hzc0mm Friend
    #380315
    OK – I worked it out myself: seems there was some error categorizing some articles. Would be fine if JA News 2 could omit empty categories automatically.
    pontikoua Friend
    #381101
    I have a similar problem with JA News 2. I have created multiples JA News2 Modules for some menu items. Works fine with the most of pages, but there is one particular page where I cannot order them to display with the order I want.
    I am trying many different things but nothing work. Re-order the modules order, re-order the sections and the categories included in the JA News, changing the order appearence on the menu item. Nothing seems to work… Any ideas? In front page for example the order work fine. The site is there : http://www.935radio.gr/935news/ and the page with the problem is : http://www.935radio.gr/935news/ειδησεις/λακωνια.html. I want the first module with title : “ΕΙΔΗΣΕΙΣ ΛΑΚΩΝΙΑ – ΕΝΗΜΕΡΩΣΕΙΣ ΑΠΟ ΤΟΥΣ ΔΗΜΟΥΣ” to be second, after the module with title : “ΕΙΔΗΣΕΙΣ ΛΑΚΩΝΙΑ”. Sorry for the greeks…!
    Any idea ?
    pontikoua Friend
    #381123
    I just did upgrade from 1.01. to 0.2 of JA News but problem persists.
    I think I am going to recreate the modules to see the behavior…
    pontikoua Friend
    #381133
    <em>@pontikoua 227381 wrote:</em><blockquote>I just did upgrade from 1.01. to 0.2 of JA News but problem persists.
    I think I am going to recreate the modules to see the behavior…</blockquote>
    I recreate the modules and things looks work out again. I also tried to put the modules on content-bot position, so now I don’t have to care so much. However it was strange behavior.
This topic contains 8 replies, has 3 voices, and was last updated by  pontikoua 13 years, 10 months ago.
