  • adrienne pitman Friend
    #877536
    1. There’s no sliding taking place
    2. The module title / label displays on the top left corner, instead of bottom left
    3. Under the Profile tab, Profile and Theme Selection are both set to nex, as specified in the documentation
    Environment:
    JA News featured Module 2.6.1
    Joomla 3.4.8
    Apache 2.4.x
    PHP 5.5.9
    1. Screenshot-2016-02-05-19.53.25
    Ninja Lead Moderator
    #878290
    The problem of your site is as this thread here, you can try to check the Mootools lib on your site.
    #878294
    Enabling Mootools made the featured article disappear,
    https://www.dropbox.com/s/duty3dc6fstigjk/Screenshot%202016-02-07%2009.16.36.png?dl=0
    #879017
    Any clue? We’re in a bit of a hurry to launch the website.
    I’ve noticed that the main article flashes for a split second, then disappears.
    Safari’s error console shows several errors related to Mootools.
    [Error] ReferenceError: Can’t find variable: Browser
    (anonymous function)
    [Error] ReferenceError: Can’t find variable: MooTools
    [Error] ReferenceError: Can’t find variable: Tips
    j
    fireWith
    ready
    J
    forEach
    each
    fireEvent
    j
    initialize
    i
    m
    #879531
    I spent a lot of my time to debug the problem on your site. Please compare both image files from my attached files, you will see the MooTools lib on your site is different and it needs to load on the top as my end.
    Do you control to change the Mootools lib on your site and make sure it loads as my screenshot?
    1. your_site
    2. my_local
    #879835
    Added Html::_(‘behavior.framework’, true); to the main index.php and apparently the problem got solved.
    Thanks for your support!
    #879927
    Cool, thank you for your sharing.
    myuption Friend
    #880331
    I have a similar issue…
    Where do you add this code?
    #880481
    @myuption: Try to use this way
    • Open templates/ja_nex_t3/index.php file and add JHtml::_(‘behavior.framework’, true); as my screenshot
    1. Screen-Shot-2016-02-10-at-10.52.34
This topic contains 8 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 11 months ago.
