May 3, 2011 at 7:16 am #389558I resolved the issue on IE by accessing the template configuration then enable the optimize css, you try checking this again
luciffere Friend
luciffere
- January 2008
- 3 times in 1 posts
May 20, 2011 at 9:45 am #392095Can be added to this extension the “timerange” function? Like JA News Pro? It be very useful this function on newspaper website.
Thank you.
May 26, 2011 at 2:06 pm #393021Hi Hung,
I tried your manual steps to add ‘mod_janews_fp ‘ to ‘sl1-l‘ position. Everything works fine, the frontpage looks good. However, the problem is the articles are still displayed on the frontpage as they are in the standard Joomla frontpage. How to get rid of them? Please see attached screenshot.
I tried to configure Home menu item (Front Page Blog Layout) to not display any article (leading=0, intro=0, etc.) then they’ve gone. But it doesn’t seem the right way to fix this issue. I am new to Joomla, please help.
thangnn1510 Friend
thangnn1510
- October 2014
- 278 times in 256 posts
May 27, 2011 at 8:35 am #393150Please try set leading = 1. There’s only one article will be shown on frontpage.
May 27, 2011 at 10:49 am #393180Found that it can be turned off by setting ‘Hide Main content block‘ to Yes in the template/profile/global settings. Thanks anyway Thang.
1 user says Thank You to hieuvo for this useful post
teutobahiano Friend
teutobahiano
- February 2011
- 9 times in 1 posts
June 17, 2011 at 12:48 pm #396911INVALID TICKET(?)
http://support.joomlart.com/index.php?/Tickets/Ticket/View/70489Anonymous Moderator
JA Developer
- 2008 times in 1700 posts
June 20, 2011 at 9:15 am #397357<em>@teutobahiano 247735 wrote:</em><blockquote>INVALID TICKET(?)
http://support.joomlart.com/index.php?/Tickets/Ticket/View/70489</blockquote>Seems that it is incorrect url
Please give me the ticket ID for further check ?
June 20, 2011 at 10:36 am #397386download link plz for j1.5(not able to find it)
teutobahiano Friend
teutobahiano
- February 2011
June 20, 2011 at 11:49 am #397396My fault! The thread was not mine! My problem is already solved.
July 21, 2011 at 3:58 am #402195teutobahiano Friend
teutobahiano
- February 2011
July 21, 2011 at 9:00 am #402253Hi gregkazakov,
I know exactly how you feel as I already have seen this “film”. In my case the reasons for the problem you are having now were:
1-No content (no articles in the configured category). Choosing all categories seems not to be a good solution. For test purpose choose one category only (with content!).
2-Configuration FEATURED/UNFEATURED: For test purpose have a mix of featured and unfeatured articles.By the way: Are you using the quickstart package or are you installing Teline4 manually? In my case I tried the manual installation first but I gave up. Seems to be an impossible mission. My site is based now on the quickstart template.
Hope this helps!
July 21, 2011 at 9:10 am #402258Thanks guys , with your help I was able to fix the problem, I was supposed to choose category and limit the auto play duration that’s all!
yes teutobahiano I wa able to install quickstart to the website online, as you already know this template tellineIV has never ending pages:laugh:
can anyone tell me how to translate the read more button for that module?July 21, 2011 at 3:13 pm #402343<em>@teutobahiano 254604 wrote:</em><blockquote>Hi gregkazakov,
Hope this helps!</blockquote>
Thanks for replying!
I am using the quickstart package with the sample data installed. I did try the manual install as well but realized it should be easier with the sample installed.
I will try your suggestions – that sound like it should take care of it.
Thanks, will let ya know how it goes!
July 21, 2011 at 4:29 pm #402348Aha! I found out the problem! I have to turn off cache for the JA News Frontpage module to see changes made. I’ll put it back on when it goes live.
thangnn1510 Friend
thangnn1510
- October 2014
July 23, 2011 at 7:05 am #402629Hi all!
We have fixed this bug:
http://pm.joomlart.com/browse/JAECMODJANEWSFP-37
and release new version. Please download and update to get fixed.
Thank you.
This topic contains 50 replies, has 32 voices, and was last updated by Saguaros 11 years, 7 months ago.
