  • hshmatera Friend
    #168845
    When i click on “Save” or “Apply”, button in back-end do not work.
    Is there any conflict?
    crazyleggs Friend
    #414389
    Can you provide more detail? Are you referring to the module?
    Have you tried the solution in this post? http://www.joomlart.com/forums/topic/save-apply-button-dont-work-in-mod_janewspro/
    hshmatera Friend
    #414404
    Yes i use mod_janewspro and mod_janews_fp on joomla 1.5
    I’ve used the quickstart package installation.
    Everithyng work fine but this two modules.
    In backend when i try to change the parameters and click on “save” something don’t work, and the buttons don’t apply the changes.
    hshmatera Friend
    #414405
    <em>@crazyleggs 269800 wrote:</em><blockquote>Can you provide more detail? Are you referring to the module?
    Have you tried the solution in this post? http://www.joomlart.com/forums/topic/save-apply-button-dont-work-in-mod_janewspro/</blockquote>
    This solution don’t work.
    Thanks anyway.
This topic contains 4 replies, has 2 voices, and was last updated by  hshmatera 13 years, 3 months ago.
