  • chris8876 Friend
    #121101
    This is what display after i update to File Version: JA News for JA Teline 1.1.2
    Read more…ArrayRALPH WILL RUN AGAIN!!ArrayGOOD NEWS FOR
    Please HELP!!
    borsato Friend
    #222875
    I have the same problem!
    What can we do about it?
    ShannonN Friend
    #222878
    What can we do about it?[/quote
    use ja news 1.13
    bigrk Friend
    #222909
    <em>@borsato 19228 wrote:</em><blockquote>I have the same problem!
    What can we do about it?</blockquote>
    You have to be a member of the Extensions Club to download JA News version 1.1.3. I would go back to version 1.1.1 and here it is:
    chris8876 Friend
    #222934
    will JA News version 1.1.3 solve the problem?
    bigrk Friend
    #222937
    That…I do not know. I haven’t joined the Extensions Club yet. But going back to the original version 1.1.1 usually fixes the problem
    ncrc Friend
    #222945
    I had the same problem, went back to 1.1.1 and its a confirmed fix for now. . .Hope to see a fix for this in newer ver soon though.. . .
    chris8876 Friend
    #223033
    I had gone back to version 1.1.1 and it took off the array but it also stop rotating,
    PLEASE HELP
    bigrk Friend
    #223089
    <em>@chris8876 19457 wrote:</em><blockquote>I had gone back to version 1.1.1 and it took off the array but it also stop rotating,
    PLEASE HELP</blockquote>
    What’s your url?
    chris8876 Friend
    #223107
    <em>@bigrk 19528 wrote:</em><blockquote>What’s your url?</blockquote>
    I install JA News 1.1.3 problem still exist, (after installing I went to the Module section and select JA News, but it says 1.1.2, even though i am a member of JAEC.) HELP!!.
    bigrk Friend
    #223126
    <em>@chris8876 19548 wrote:</em><blockquote>I install JA News 1.1.3 problem still exist, (after installing I went to the Module section and select JA News, but it says 1.1.2, even though i am a member of JAEC.) HELP!!.
    http://www.belizetimes.biz</blockquote>
    You will need to get help for version 1.1.3 in the Extensions category here in the forum. As a member of the JAEC you should have access to that area. I haven’t seen this version myself yet.
    Bryan Villeneuve Friend
    #223955
    I have the same problem with 1.1.2. Going back to 1.1.1 fixed it. Many thanks!
    bigrk Friend
    #223958
    <em>@birddog 20586 wrote:</em><blockquote>I have the same problem with 1.1.2. Going back to 1.1.1 fixed it. Many thanks!</blockquote>
    Glad to hear it and now good luck with moving on to developing the site. 🙂
    dpk Friend
    #229357
    Try the Larix template version of JA News if you can’t get the others to work… More here:
    http://www.joomlart.com/forums/topic/user-tools-not-showing-2/
This topic contains 14 replies, has 7 voices, and was last updated by  dpk 17 years, 1 month ago.
