March 24, 2007 at 4:43 am #119325
I would like to move the JA news module right up under the user1, user2, and top module. Here is a screenshot of what I currently have, What do I need to change in the index file to change that? Thanks for your help.
<?php
# JA Xenia II - Feb, 2007
# Copyright (C) 2004-2006 J.O.O.M Solutions Co., Ltd. All Rights Reserved.
# @license - Copyrighted Commercial Software
# Author: J.O.O.M Solutions Co., Ltd
# Websites: http://www.joomlart.com - http://www.joomlancers.com
-------------------------------------------------------------------------*/defined( '_VALID_MOS' ) or die( 'Restricted access' );
$iso = split( '=', _ISO );
/*echo "<?xml version="1.0" encoding="'. $iso[1] .'"?' .'>";*/
global $ja_color_themes, $ja_header_images, $ja_width_default, $ja_color_default, $ja_font_size_default, $ja_tool, $ja_menutype, $ja_template_path, $ja_template_absolute_path, $ja_headerimg, $ja_color, $ja_width, $ja_font_size, $ja_template_name;$ja_template_name = 'ja_xenia_ii_gamer';
# BEGIN: TEMPLATE CONFIGURATIONS ##########
#support extra color themes
$ja_color_themes = array('default', 'blue', 'orange'); // You can add more color array if needed
# Change the width of the template
$ja_width_default = 'wide'; // 'narrow': 800x600; 'wide': 1024x768; 'auto': fluid width
# default color
$ja_color_default = 'default'; //blank for default, else pick one of in extra color themes $ja_color_themes
#font size default
$ja_font_size_default = 3;
# Enable users option
$ja_tool = 3; // 0: disable all; 1: disable color, enable font; 2: enable color, disable font; 3: enable all.
# Choose your prefer Menu Type
$ja_menutype = 1; // 1: Split Menu; 2: Son of Suckerfish Dropdown Menu; 3: Transmenu; 4: Script Dropline Menu;
# END: TEMPLATE CONFIGURATIONS ########### Define the template path ##########
$ja_template_path = $mosConfig_live_site.'/templates/'.$ja_template_name;
$ja_template_absolute_path = $mosConfig_absolute_path.'/templates/'.$ja_template_name;
include ($ja_template_absolute_path."/ja_templatetools.php");$topnav = "";
$subnav = "";
if ($ja_menutype == 1) {
require($ja_template_absolute_path."/ja_splitmenu.php");
$topnav = ja_topNav('mainmenu', array('default'));
$subnav = ja_subNav('mainmenu');
} else if ($ja_menutype == 4) {
require($ja_template_absolute_path."/ja_scriptdlmenu.php");
$topnav = $jamenu->menuObj->main;
$subnav = $jamenu->menuObj->sub;
}# Auto Collapse Divs Functions ##########
$ja_left = mosCountModules( 'left' );
$ja_right = mosCountModules( 'right' );if ( $ja_left && $ja_right ) {
$divid = '';
} elseif ( $ja_left ) {
$divid = '-fr';
} elseif ( $ja_right ) {
$divid = '-fl';
} else {
$divid = '-f';
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><head>
<?php mosShowHead(); ?>
<meta http-equiv="Content-Type" content="text/html; <?php echo _ISO; ?>" />
<meta http-equiv="Content-Style-Type" content="text/css" /><link href="<?php echo $ja_template_path;?>/css/template_css.css" rel="stylesheet" type="text/css" />
<link href="<?php echo $ja_template_path;?>/css/colors/<?php echo $ja_color; ?>.css" rel="stylesheet" type="text/css" />
<link href="<?php echo $ja_template_path;?>/css/ja-news.css" rel="stylesheet" type="text/css" /><script language="javascript" type="text/javascript" src="<?php echo $ja_template_path;?>/scripts/ja.script.js"></script>
<?php genMenuHead(); ?>
<?php if ( $my->id ) { initEditor(); } ?>
<style type="text/css">
.clearfix { height: 1%;}
</style>
.clearfix { display: inline-block;}
</style>
</head><body id="bd" class="<?php echo "$ja_width fs".$ja_font_size;?>">
<a title="Skip to content" href="<?php echo getCurrentURL();?>#Content" style="display: none;">Skip to content</a>
<a name="Top" id="Top"></a><div id="ja-wrapper">
<div id="ja-wrapper-inner"><!-- BEGIN: HEADER -->
<div id="ja-headerwrap">
<div id="ja-header" class="clearfix">
<h1>
<a href="index.php">
<img src="<?php echo $ja_template_path;?>/images/logo-<?php echo $ja_color; ?>.jpg" alt="<?php echo $mosConfig_sitename?>" />
</a>
</h1>
<?php if (mosCountModules('user3') ) { ?>
<div id="ja-topnavwrap" class="clearfix">
<?php mosLoadModules ( 'user3', -1 ); ?>
</div>
<?php } ?><?php if (mosCountModules('user4')) {?>
<div id="ja-search">
<?php mosLoadModules ( 'user4', -1 ); ?>
</div>
<?php } ?></div>
</div>
<!-- END: HEADER --><!-- BEGIN: MAIN NAVIGATION -->
<div id="ja-mainnavwrap" class="clearfix">
<div id="ja-mainnav">
<?php
switch ($ja_menutype) {
case 1: echo $topnav;
break;
case 2:
include($ja_template_absolute_path."/ja_cssmenu.php");
break;
case 3:
echo "<div class="transmenu-inner">";
include($ja_template_absolute_path."/ja_transmenu.php");
echo "</div>";
case 4:
echo $topnav;
break;
</div><?php if ($ja_tool) {?>
<div id="ja-usertoolswrap">
<span class="ja-sitetool">Site Tools</span>
<div id="ja-usertools" style="left:<?php echo ($ja_tool==3)?-90:(($ja_tool==2)?0:-40); ?>px">
<?php genToolMenu($ja_tool); ?>
</div>
</div>
<?php } ?>
</div><div class="ja-mainnavshadow"></div>
<?php if ($subnav) { ?>
<div id="ja-subnav" class="clearfix">
<?php echo $subnav; ?>
</div>
<?php } ?><div id="ja-containerwrap">
<div id="ja-container<?php echo $divid ?>" class="clearfix"><!-- BEGIN: CONTENT -->
<div id="ja-mainbody<?php echo $divid; ?>"><?php if( mosCountModules('header') ) {?>
<div id="ja-sh" class="clearfix">
<?php mosLoadModules('header', -1); ?>
</div>
<?php } ?><a name="Content" id="Content"></a>
<div id="ja-contentwrap">
<div id="ja-content">
<div id="ja-pathway">
<strong>You are here:</strong> <?php mosPathway(); ?>
</div><?php
$spotlight = array ('user1','user2','top');
$topspl = calSpotlight ($spotlight);
if( $topspl ) {
<!-- BEGIN: TOP SPOTLIGHT -->
<div id="ja-topslwrap">
<div id="ja-topsl" class="clearfix">
<?php if( mosCountModules('user1') ) {?>
<div id="ja-topsl1" class="ja-box<?php echo $topspl['modules']['user1']; ?>" style="width: <?php echo $topspl['width']; ?>;">
<?php mosLoadModules('user1', -2); ?>
</div>
<?php } ?><?php if( mosCountModules('user2') ) {?>
<div id="ja-topsl2" class="ja-box<?php echo $topspl['modules']['user2']; ?>" style="width: <?php echo $topspl['width']; ?>;">
<?php mosLoadModules('user2', -2); ?>
</div>
<?php } ?><?php if( mosCountModules('top') ) {?>
<div id="ja-topsl3" class="ja-box<?php echo $topspl['modules']['top']; ?>" style="width: <?php echo $topspl['width']; ?>;">
<?php mosLoadModules('top', -2); ?>
</div>
<?php } ?>
</div>
</div>
<!-- END: TOP SPOTLIGHT -->
<?php } ?>
<?php
global $mainframe, $option;
$m_menu = $mainframe->get( 'menu' );
$m_params = new mosParameters( $m_menu->params );$m_intro = $m_params->def( 'intro', 4 );
$m_leading = $m_params->def( 'leading', 1 );
if ( $option != 'com_frontpage' || $m_intro || $m_leading) {
<?php mosMainBody(); ?>
<?php } ?>
<?php if ( mosCountModules('ja-news') ) { ?>
<div id="ja-newswrap">
<?php mosLoadModules ( 'ja-news', -2 ); ?>
</div>
<?php } ?><?php if ( mosCountModules('banner') ) { ?>
<div id="ja-banner">
<?php echo mosLoadModules ( 'banner',-1 ); ?>
</div>
<?php } ?></div>
</div><?php if ($ja_right) { ?>
<!-- BEGIN: RIGHT COLUMN -->
<div id="ja-rightcol">
<div id="ja-rightcol-inner">
<?php echo
mosLoadModules ( 'right',-3 );
</div>
</div>
<!-- END: RIGHT COLUMN -->
<?php } ?></div>
<!-- END: CONTENT --><?php if ($ja_left) { ?>
<!-- BEGIN: LEFT COLUMN -->
<div id="ja-leftcol">
<?php echo
mosLoadModules ( 'left',-2 );
</div>
<br />
<!-- END: LEFT COLUMN -->
<?php } ?></div>
</div><!-- BEGIN: FOOTER -->
<div id="ja-footerwrap">
<?php
$spotlight = array ('user7','user8','user9');
$botsl = calSpotlight ($spotlight);
if( $botsl ) {
<div id="ja-botsl" class="clearfix">
<?php if( mosCountModules('user7') ) {?>
<div class="ja-box<?php echo $botsl['modules']['user7']; ?>" style="width: <?php echo $botsl['width']; ?>;">
<?php mosLoadModules('user7', -2); ?>
</div>
<?php } ?><?php if( mosCountModules('user8') ) {?>
<div class="ja-box<?php echo $botsl['modules']['user8']; ?>" style="width: <?php echo $botsl['width']; ?>;">
<?php mosLoadModules('user8', -2); ?>
</div>
<?php } ?><?php if( mosCountModules('user9') ) {?>
<div class="ja-box<?php echo $botsl['modules']['user9']; ?>" style="width: <?php echo $botsl['width']; ?>;">
<?php mosLoadModules('user9', -2); ?>
</div>
<?php } ?>
</div>
<?php } ?>
<div class="clr" ></div>
<div id="ja-footer">
<div id="ja-sublogo">
<img src="<?php echo $ja_template_path;?>/images/sub-logo.gif" alt="<?php echo $mosConfig_sitename?>" />
</a>
</div>
<p id="ja-bottomline">
<?php include_once( $ja_template_absolute_path.'/footer.php' ); ?>
</p><div id="ja-cert">
<a href="<?php echo $mosConfig_live_site ?>/index.php?option=com_rss&feed=RSS2.0&no_html=1" target="_blank" title="RSS 2.0" style="text-decoration: none;">
<img src="<?php echo $ja_template_path;?>/images/but-rss.gif" alt="RSS 2.0" />
</a>
<?php if ($ja_menutype != 3 ) { ?>
<a href="http://jigsaw.w3.org/css-validator/validator?uri=<?php echo $mosConfig_live_site;?>" target="_blank" title="Our site is valid CSS" style="text-decoration: none;">
<img src="<?php echo $ja_template_path;?>/images/but-css-<?php echo $ja_color; ?>.gif" alt="Our site is valid CSS" />
</a>
<?php } ?>
<a href="http://validator.w3.org/check/referer" target="_blank" title="Our site is valid XHTML 1.0 Transitional" style="text-decoration: none;">
<img src="<?php echo $ja_template_path;?>/images/but-xhtml10-<?php echo $ja_color; ?>.gif" alt="Our site is valid XHTML 1.0 Transitional" />
</a>
<a href="<?php echo getCurrentURL();?>#Top" title="Go to top" style="text-decoration: none;">
<img src="<?php echo $ja_template_path;?>/images/but-top-<?php echo $ja_color; ?>.gif" alt="Go to top!" />
</a>
</div>
</div>
</div>
<!-- END: FOOTER --></div>
</div><?php mosLoadModules( 'debug', -1 );?>
</body></html>
Hung Dinh FriendHung Dinh
- 3310 times in 3 posts
March 24, 2007 at 8:54 am #2164171. Search and delete this code in in the index.php for
</div>
<?php } ?>
2. search for<!-- END: TOP SPOTLIGHT -->
and add belows this line:
</div>
<?php } ?> -
This topic contains 2 replies, has 2 voices, and was last updated by Hung Dinh 17 years, 8 months ago.
