  • morladim Friend
    #167183
    Hey guys,
    A couple of the menu items don’t link properly and because it’s only on some menu items I’m not sure what’s wrong. Please take a look:
    The ‘Launches’ link leads to:
    http://wikiwarrior.com/launches
    …which is correct, but…
    The ‘Get Started’ Menu item leads to this link:
    http://wikiwarrior.com/component/content/section/5
    What have I done for the get started menu item link to be wrong and how can I fix this?
    Any help would be greatly appreciated.
    Thanks.
    chavan Friend
    #405030
    The get-started link is good in the site this is the link http://wikiwarrior.com/get-started not the one you have posted.
    I hope you might haven’t cleared you joomla clean cache and the browser cache.
    morladim Friend
    #405527
    Hi Chavan,
    Thanks for your response. That link you replied with only appears in the top menu for me. In JA News Pro it has the /component link. I just don’t know what is wrong. Anyway, I have just unpublished the menu so it isn’t visible on the FP any more. Not exactly a solution but a workaround until I get to grips with the template.
This topic contains 3 replies, has 2 voices, and was last updated by  morladim 13 years, 3 months ago.
