namko Friend
namko
- February 2012
April 26, 2012 at 8:54 pm #176520On sl-1 position under JA News Featured module, when i add one more module ( see pictures) my JA News pro module extends on sl-2 position. i like to be on same level line with JA News Featured module.
URL: http://www.balkan-caffe.com
Tamplet: JA NexCan you please help me with this issue.
Saguaros ModeratorSaguaros
April 27, 2012 at 10:01 am #450494Hi there,
It should be fine when you install a new module in sl1-1 position. Please send me login details of your site. I’ll check this for you.April 27, 2012 at 11:53 am #450517namko Friendnamko
- February 2012
April 27, 2012 at 1:38 pm #450529<em>@Hien Nguyen 316458 wrote:</em><blockquote>Hi there,
It should be fine when you install a new module in sl1-1 position. Please send me login details of your site. I’ll check this for you.</blockquote>Hi Hien Nguyen
I already send the PM with all of the information you requst.
Thank you for your great support
namko Friendnamko
- February 2012
April 27, 2012 at 2:05 pm #450536<em>@Hien Nguyen 316458 wrote:</em><blockquote>Hi there,
It should be fine when you install a new module in sl1-1 position. Please send me login details of your site. I’ll check this for you.</blockquote>I already added (install) another module on sl-1 position and thats why they module extend sl-2 position. When i add another module on sl-2 position they extend it more.
Thank you very much for your help I already sent you the pm with the account infoiluminada Friendiluminada
- September 2010
- 2 times in 1 posts
April 29, 2012 at 8:02 pm #450693Please, I dont´’ understand the answer. I have the same problem with mod_janewspro in sl-2 position that extends below the modules at SL-1 and SL-3…I don’t understand how was the solution..!
- September 2010
May 3, 2012 at 12:56 pm #451252I have not installed adifferent module in sl1.1. In sl1.1 is JA Featured News and in sl1.2 I have JA News Pro module. I send a picture of the problem. Please I need help.
May 4, 2012 at 2:47 am #451339Hi there,
Could you send me url of site you’re working on? and please tell me how you want it should display and please set CSS compression in template manager in backend to No
Thanks.iluminada Friendiluminada
- September 2010
May 4, 2012 at 1:14 pm #451431Hi, I send the URL for PM. I send here the image of how I want to be the height of the module, aligned with the height of the module sl1-1…
May 8, 2012 at 9:21 am #451990Hi iluminada,
You can increase padding-bottom for JA News Featured module in sl1-1 position so that it has same height with module in sl-2 position.
Within this file:
templatesja_nexhtmlmod_janews_featurednexstyle.css
Add this code:
ja-moduletable moduletableno-padding absolute-title simple-title{
padding-bottom: 33px; <<< this value depends on you.
}iluminada Friendiluminada
- September 2010
May 8, 2012 at 2:31 pm #452046Saguaros, I add the code you send me in style.css:
padding-bottom: 103px;
(changing to differents values)
But there are not changes.
When I look the problem with firebug there are only
element.style {
min-height: 653px;
in both modules, in sl1-1 and sl1-2.
When I change min-height to 620px, is all good…Where can I change this code??
- September 2010
May 9, 2012 at 2:53 pm #452236Excuse me for to answer late.
I tried changing the measure of padding-bottom but nothing happens, there are not changes in JA News Featured in sl1-1 position (I have padding-bottom: 203px;)
Anyway I prefer to remove white space instead of adding, removing the bottom of JA News Pro! Module in sl1-2…
Do you have another idea?iluminada Friendiluminada
- September 2010
May 9, 2012 at 3:03 pm #452237Sorry, I had not read the last post.
I changed the settings in style.css and I see no changes. As I don’t find the style in firebug, I can’t do tests to see if changing the values are any change, but putting the padding in 17 nothing happens.iluminada Friendiluminada
- September 2010
May 10, 2012 at 4:24 pm #452423Saguaros, I read another post:
http://www.joomlart.com/forums/topic/module-in-position-sl1-1/
Say me if you think would be a solution…AuthorPostsThis topic contains 31 replies, has 6 voices, and was last updated by ramonesmania 12 years, 6 months ago.
