Viewing 15 posts - 1 through 15 (of 55 total)
  • APOSTOLOS FOUKIS Friend
    #157408
    JA Teline IV 1.1.0
    I’ve install & reinstall again JA News Pro 1.0.0 but when i want to use it … i press “Save” but don’t save, so i can’t use it
    cepedalc Friend
    #366636
    I am assuming you have moved from a previous version to T4 as an upgrade, in this case, have you installed all the T3 Framework extensions and Published them accordingly? I had the same issue and I was missing a T3 plug, don’t remember but I believe one of them was not published yet.
    Also I will add a question to yours here: what is the settings in this module for the part since the user guide skipped it.
    1. Menu-assigment
    #366766
    i try it but not works
    steinar Friend
    #366781
    <em>@basdim 208534 wrote:</em><blockquote>i try it but not works</blockquote>
    Make sure you have the current version of the JA News Frontpage Module, version 1.3.5.
    #366785
    I’d use ja extensions manager to update all …
    i’ve news fp v 1.3.5
    but not works news pro module
    steinar Friend
    #366796
    Maybe you would like to try this initial setup of JA_News_fp, which works for me:
    Details:
    Enabled, position: sl1-l
    Menu assignment:
    Magazine>Home
    Module Parameters:
    class suffix: newsfp
    profile selection: default
    content settings:
    Source: Joomla content; all categories
    thuanlq Friend
    #366856
    @basdim: current version of ja news pro is 1.0.1, please update new version for it
    thankx
    coriandolorosso Friend
    #367369
    <em>@thuanlq 208637 wrote:</em><blockquote>@basdim: current version of ja news pro is 1.0.1, please update new version for it
    thankx</blockquote>
    Not ready? http://pm.joomlart.com/browse/JAECMODNEWSPROJV#selectedTab=com.atlassian.jira.plugin.system.project%3Aversions-panel
    In Downloads Area there’s only Ja NewsPro 1.0.0 http://www.joomlart.com/forums/downloads.php?do=cat&id=381
    :confused:
    christool Friend
    #367370
    I ‘ve got the same issue with both janews pro and janews fp, i have installed the last quickstart package.
    thuanlq Friend
    #367676
    janews pro and janews fp modules are using profiles, when i config some params of these modules and save it, their params are saved to profile file in “Profiles” folder, if it has error while saving, the changes will not be saved.
    – latest version of janews pro is 1.0.1 (Improvement and fix bug)
    – latest version of janews fp is 1.3.6 (Improvement and fix bug)
    k0nan Friend
    #369816
    i can’t save or apply and my versions are
    janews pro 1.0.2
    janews fp 1.3.6
    …. what’s up ?
    jantunes Friend
    #369849
    I can’t save also. And I’ve installed a quickstart on the same server and all works ok, so I don’t understand why on a upgrade solution, where everything else is working, the JA News FP e News Pro don’t save… Iam using FP from Teline III for now, waiting for an answer. And there seems to be more people with the same problem. Any hint?:((
    axelf Friend
    #369891
    Same problem here, cannot do “Save” or “Apply”.
    k0nan Friend
    #369892
    i’ve opened a support ticket about 10 hours ago and i’ve not received any reply yet… what’s up?
    what’s the magic in the live demo and in the kickstart that simply can’t be in a normal template/module installation ?
    concluding: have i payed for smth that is simply not working ?
    this backend problems occur with latest ja teline IV, latest t3, latest modules versions, php 5.2 on mac/win webkit/mozilla/ie… but not on localhost, what’s up guys ? 🙂
    jantunes Friend
    #369896
    Get in the line, please. I openeed a support ticket yesterday and besides a quick visit to the site early morning, nothing happenned. And I simply can not figure it out although I’ve been the only day around it… Localhost, quickstart, same server as my website, everything works… but not on my main site.
    At the momnent Iam using JA News FD from Teline III and it’s working, but not as I wanted my FP to be… If I upgrade it I get the problem again. And I’ve no chance with JA News Pro… If it’s not the PHP and all the rest, what is it?
This topic contains 55 replies, has 24 voices, and was last updated by  Sherlock 13 years, 6 months ago.
