  • martin tu Friend
    #187160
    Hi Sir,
    Please kindly see the attachment for the problem.
    Setting
    Thank you,
    Martin.
    1. JA-News-Pro-Module-problem-picture-out-of-frame
    2. STEMI.TV-adm
    Hi Martin,
    The second screenshot is backend settings of JA News Feature module while the first screenshot shows problem with JA News Pro module, kindly check again.
    You can also have a look at userguide of this JA Nex template to see how we configure for this JA News Pro module: http://www.joomlart.com/forums/topic/userguide-ja-nex-template-for-joomla-2-5/ (section 2.3 Music News)
    martin tu Friend
    #492391
    Hi Sir,
    Sorry, here JA News Pro backend attachment
    For your information:
    This problem shows after I had changed JA News pro blog_item.php for adding links
    http://www.joomlart.com/forums/topic/how-to-add-link-into-ja-news-feature-picture/
    Thank you again,
    Martin.
    1. STEMI.TV-mod_janewspro
    HI Martin,
    Could you pm me url and admin account of your site? I will check it for you.
    martin tu Friend
    #493680
    Thank you , plz check PM. 🙂
    Hi Martin,
    Try opening file: /templates/ja_nex/css/template.css
    add this css rule:
    #ja-topsl1 .ja-zincontent img {
    margin-left: -13px;
    margin-right: -12px;
    margin-top: -8px;
    Once done, clean JAT3 cache.
    Hope this helps.
    martin tu Friend
    #495865
    hi Sir,
    Thank you. I add the css rule, please see the attachment for what happend.
    Thank you,
    Martin.
    1. print-screen
    Hi Martin,
    I’ve just add a new class suffix for this module in backend, you can change above css rule to:
    #ja-topsl1 .added .ja-zincontent img {
    margin-left: -13px;
    margin-top: -8px;
    Then clean JAT3 cache.
    martin tu Friend
    #496331
    Solved! Thank you Sir. :laugh:
    Note: I had removed ‘.’ before ‘#ja-topsl1 .added .ja-zincontent img {‘ to make it work.
This topic contains 9 replies, has 2 voices, and was last updated by  martin tu 11 years, 6 months ago.
