Viewing 15 posts - 1 through 15 (of 17 total)
  • willylord Friend
    #184927
    sorry for my english.
    In my website, I show only articles in the last 6 months. The others all are marked as “stored”.
    Most of subcategories is not longer valid, because they’s categories of the old archived articles, not longer visible.
    Can I hiding the subcategories that have NO articles, yet?
    See attachment.
    1. JA-news-pro
    steinar Friend
    #483311
    Hello willylord,
    Try Extensions >> Module manager >> JA News Pro >> Basic options >> Content settings. Here you can select the categories you want to show (and even set a time range).
    Ciao!
    willylord Friend
    #483312
    Thanks, but does not work. When I select a main category still see ALL the subcategories.
    HeR0 Friend
    #483361
    Hi Willylord,
    If you want to hide category which has no article, plz disable those categories in categories management.
    willylord Friend
    #483805
    Not works 🙁
    If enabling each category individually, on the frontend, I see all the subcategories like many master category.
    willylord Friend
    #483818
    The real problem is that JA News Pro show the trashed and archived categories, too.
    Otherwise, could I store or trashing these without problem, for not showing yet 🙁
    I have discovered that “linear” layout using a caching sytem for store the subcategories.
    Can you help me?
    HeR0 Friend
    #483862
    Hi Willylord,
    Plz pm me ftp info, url and admin account for further checking and I will try to help you out.
    willylord Friend
    #483920
    Hi, I sent you all the access info 😉
    I have discovered that the problem (when I move the categories in the Archive) is the caching of this module, but via FTP in can’t delete the files on cache/mod_janewspro/*
    Can you help me?
    MoonSailor Friend
    #483963
    Hi willylord,
    Pls check PM.
    Regards.
    willylord Friend
    #484061
    sent PM 🙂
    willylord Friend
    #484141
    Hi, have you got any news?
    willylord Friend
    #484753
    Up . Up . Up . :((
    MoonSailor Friend
    #484867
    Hi willylord,
    I tried to edit file but it seems that the account you gave doesn’t have permission to edit. You can fix as following:
    – Open file “/modules/mod_janewspro/helpers/adapter/content.php”
    – Go to line 166 :
    [PHP]
    165 : $articles = $this->getArticles($catids, $helper, $params_cat);
    166 : }
    [/PHP]
    add code after “}” :
    [PHP]
    $categoriespush = array();
    foreach($_categories_org AS $cat){
    if($this->getArticles($cat->id, $helper, $params_cat)){
    array_push($categoriespush,$cat);
    [/PHP]
    find code
    [PHP]
    $helper->_categories_org[$catid] = $_categories_org;
    [/PHP]
    change to :
    [PHP]
    $helper->_categories_org[$catid] = $categoriespush;
    [/PHP]
    You can see images attachment 🙂
    1. 2-28-2013-2-46-59-PM
    willylord Friend
    #484905
    Thanks. I have some problems with server, too. :((
    Later, I try to modify the page and unlock the permission.
    Thanks!
    willylord Friend
    #484924
    (Excuse me, but this Ftp I can upload that file without problems.)
    Ok. I have take the modify but cannot works 🙁
    Have you got any problem with Ftp permission ? (I have modify the file owner, too)
This topic contains 17 replies, has 4 voices, and was last updated by  willylord 11 years, 9 months ago.
