  • maksem Friend
    #129252
    I want to change “read more” to “devamı” which is Turkish of it. For this purpose I changed the modules/mod_janews/mod_janews.php line 153 as follows:
    echo “<a href=”$link” class=”readon”>devamı</a>”;
    When I refreshed the page, the JA News loaded correctly. But when it starts to load other news, it shows again “read more” instead of “devamı”. Why it loads correctly first and wrong all the other rolls? How can I solve this problem?
    Thanks for your response.
    bennitos Friend
    #251786
    I think you would be better of with installing the turkish frontend language pack, everything on the front end will be turkish then. Will save you a lot of manually transulating.
    You will find it here:
    http://extensions.joomla.org/component/option,com_mtree/task,viewlink/link_id,2292/Itemid,35/
    Make that language default on the front end and everything will be turkish (including the ‘read more’ part)
    maksem Friend
    #251787
    <em>@bennitos 56844 wrote:</em><blockquote>I think you would be better of with installing the turkish frontend language pack, everything on the front end will be turkish then. Will save you a lot of manually transulating.
    Make that language default on the front end and everything will be turkish (including the ‘read more’ part)</blockquote>
    Thanks. Turkish Language Pack was already installed. The other parts of the site is Turkish but there is a local problem as I explained.
This topic contains 3 replies, has 2 voices, and was last updated by  maksem 16 years, 7 months ago.
