JA News2 / JAZin is creating problem in in the magazine menu. I will write one by one here what I did:
1) In the attached document you can see two instances where title shows up and does not shows up in other instance. This happens when you bring mouse close to ‘Projects section’ then title disappears, however if you take the mouse to somewhere else then title reappears. To check this I opened the JAzin plugin and tries to change some parameters. In the parameters section I changed ‘Add Home item’ to No. When I checked my website ‘Home’ menu of the magazine menu has disappeared. eventually, all the Ja tabs, Ka News 2 etc. every thing disappeared.
2) I copied the Home menu from main menu and reinstalled / activiated JA tabs , JA News2 etc; every thing was back as I got back the Home menu inthe magazine menu.
3) To play it further, I agian opened the JAZin Plugin, changed the parameter ‘Add Home Item’ to Yes, now you can see clearly that I have now two ‘Home’ menus in the attached docuemnt (third picture) or you can check my website.
There is something wrong with JaZIn plugin or my undersstanding is wrong.
regards,
