  • eserdark Friend
    #131679
    I have been working with Joomla 1.5 and JA Iris. In established joomla with JA Iris, the Newsflash module causes unlink on the left menu. When I have determine no article for JA Newsflash module, there is no problem. But after only one simple article selected, Left menĂ¼ has no link.
    My site is http://www.kmo.org.tr/index.php to see it.
    Are there any other webmaster with this problem, how can I solve?
    eserdark Friend
    #263527
    by cleaning <div class=”nfimages”>##IMAGE##</div> row from template section on JA news Module.
    Still what is the explanation ?
    bydler Friend
    #265673
    I have the same problem, all links on the left side (until you get down on the page a bit) are impossible to click on.
    I thought this had something to do with the fact that I have duplicated the main menu and put it again under the newsflash but if not and if you have found a solution I’m most happy!
    I can’t find the file you are talking about though, could you write down the full path so I can see if your solutions resolves my problems as well? In mod_janewsflash I only have reference to title and content and now I can’t think of anywhere else to look. I have of course also searched index.php and template_css.css for the image class but without luck.
    Thank you!
    bydler Friend
    #265690
    I finally found the answer to at least my own problem: In mod_janewsflash the height of the div was set to 300 but the real height is only 175. After I changed that the links worked like they should.
This topic contains 4 replies, has 2 voices, and was last updated by  bydler 16 years, 3 months ago.
