  • edd Friend
    #130618
    Hi there,
    I’ve installed the JA Newsflash that works perfect, just one little thing: when I use spanish accents, like: ñ; é etc or kind of french accents: à; ç; ù etc… it is just showing the “?” symbol…
    I really need help with this, thanks for replys
    canadatom Friend
    #258903
    1.0.15? what’s encoding of the website?
    #258908
    Hi edd !
    what template package do you use ? It’s best if you send url of your site.
    edd Friend
    #260745
    Hi there…
    I use EDENITE 1.0.15
    I’m just working on local by the moment, any idea?
    Thanks for your interest! 😉
    edd Friend
    #261580
    non one has any idea?
    I really need help on this! :((
    Please…
    jantunes Friend
    #261702
    Well, I guess it is the same problem I’ve in all my templates…. If Iam not using the language file for my country (and I don’t) when I’ve words with accents over them, that are not recognised by the system, I just get a strange character at the end of the JANEWS sentence. Just there, but it does happen. My solution: write phrases without the specific letters and accents near the end of the news piece… pelase check
    http://www.fotodigital-online.com
    if you browse over the news on each section you might just find one or two places where I forgot to fix it…
    Hope this helps
    #261916
    Hi all !
    sorry for delay !
    I have test your problem in my site with vietnamese languguage and utf-8 charset , but can’t appears the problem, can one of you send admin info via pm for me, i will check to detect the problem and JA Developer will fix it. Now , i can’t detect the problem.
    #262158
    Hi all !
    thanks you for report about JA Newsflash bug ! We will update it in new version. for fix encoding bug of JA Newsflash for joomla 1.5 please download mod_janewsflash.zip file and reinstall it on your site.
    edd Friend
    #262234
    HI!!! 😀
    Thanks a lot for update!!!
    what about for 1.0.X versions?
    I’m using 1.0.15, could I spect an update?
    furchtlos76 Friend
    #264361
    Anyone got a fix for that working on Joomla 1.0.x ? Tryed everything, but after the first rotate my german chars like ä ü ö are just sqares or strange chars =(
    edd Friend
    #267284
    http://www.joomlart.com/forums/images/icons/announce.gif
    Please, some answer about JA Newsflash for 1.0.x
    is it possible to spect an update?
    #267337
    Hi edd !
    I will do it for you ! but what template package do you use ?
    #267341
    Hi edd !
    Please try to use attachment below ,
    reinstall mod_janewsflash.
    edd Friend
    #267414
    Hi hainn84 🙂
    Thanks for your help…
    I’m using EDENITE 1.0.15 (sorry if I use a 1.0.15 version, but the site was built on 1.0.12 so I made an update to 1.0.15 and using EDENITE)
    So I downloaded your file, I uninstall the old one, and went to the module folder and look if there is no more the old one (mod_janewsflash).
    After the new installation it seemed to work fine because the first article showed without problems the accents… but… but… :(( for the second and third articles there was this bloody “?” sign >:(
    So when the first one appeared again, there was the “?” symbol and so on…
    Sorry ! and thanks for you help, hope this can work one day! 😉
    #267461
    Hi edd !
    Please send url of your site and admin acc via pm , i will check it for you !
This topic contains 15 replies, has 5 voices, and was last updated by  Sherlock 16 years, 4 months ago.
