test melih
 melih
Viewing 15 posts - 31 through 45 (of 49 total)
  • elocuent Friend
    #454178
    hi, so you mean having a menu item for every single category? but somehow invisible in the main menu?
    They are already inside a “father” category that is in menu
    And still i have articles with same category one linking while the other does not.
    Hi elocuent,
    when you open an article but it still stays on the homepage, it means this article ( or category this article belongs to) has not been assigned to any menu item. This menu item can be in menu of first level or sub menu and make sure that you don’t assign any module to this menu item.
    Hope you got this idea.
    cimfema Friend
    #454258
    Hi support team!
    I have a question about the module Ja News…
    If I click on “setting” in the bar of Ja news module, in one section appear this menu:
    There are all the check boxes selected
    In another section the menù is different:
    Only some check boxes are selected.
    This is what happen on a computer that access the site for the first time, like a “default setting”.
    Should be possible have the same situation in all the sections?
    (with all the check boxes selected?)
    Many thanks for your support
    Marco
    1. Janews-2
    2. Janews-1
    Hi Marco,
    You can set the number of categories display by default in backend by changing maximum number of categories
    Hope this help
    1. maxcate
    gatmanu Friend
    #456938
    I need to translate text parts from this module like “ALL” (in the list of categoies) and “AGO” (beside the timestamp)
    which file shall I modify ?
    is it also possible to order the grouped categories ? it seems that the module orders by id
    #457021
    Hi gatmanu,
    <blockquote> I need to translate text parts from this module like “ALL” (in the list of categoies) and “AGO” (beside the timestamp)
    which file shall I modify ?</blockquote>
    1) you open the file of modulesmod_janewsprotmpllinearblog.php look for this code
    [PHP]JText::_(‘All’)[/PHP]
    change it to
    [PHP]JText::_(‘JANEWSPRO_ALL’)[/PHP]
    2) Now you can open module language file languagethe_active_languagethe_active_language.mod_janewspro.ini and adding translating texts as below
    JANEWSPRO_ALL=”your text goes here”
    AGO=”your text goes here”
    <blockquote>is it also possible to order the grouped categories ? it seems that the module orders by id</blockquote>
    I am not much sure what you meant, I think it’s ordered by categories id first then to article-id
    gatmanu Friend
    #457096
    I modified the files but nothing changed. I Tried and tried again but nothing…
    Almost got mad until I figured out that the module had cache ! 😉
    Now It works. Thanks to you
    regarding the order of the categories, my question was in fact :
    is it possible to order the categories not by id but with the ordering defined in the admin instead ? (content/categories)
    flashlan Friend
    #466370
    Dear JA
    I am using this module. I have one category and I want to use 3 articles in 1 category. When I do it in settings, it shows 3 articles under each other. But I want to display 3 articles in 1 category side by side. Is it possible?
    #466406
    <em>@flashlan 337277 wrote:</em><blockquote>Dear JA
    I am using this module. I have one category and I want to use 3 articles in 1 category. When I do it in settings, it shows 3 articles under each other. But I want to display 3 articles in 1 category side by side. Is it possible?</blockquote>
    Hi flashlan,
    which theme are you using for the module ? Can you share with me here the url where the issue is seen ?
    creativedesigns Friend
    #471531
    With JA News Pro Module, I need one featured article displayed at the top of the category page permanently. So for example, one page will be for Insurance, one page will be for medical, one page will be for tax. When someone clicks on the header on the homepage, and it takes them to the category page, the featured article needs to always be shown at the top of the articles.
    How do I do this?
    flashlan Friend
    #471533
    <em>@Sherlock Holmes 337325 wrote:</em><blockquote>Hi flashlan,
    which theme are you using for the module ? Can you share with me here the url where the issue is seen ?</blockquote>
    http://xezeridman.com/
    Hi flashlan,
    Currently, it only support to display 3 categories side by side, not 3 articles under 1 category like that. You need to customize this module to achieve that.
    cimfema Friend
    #474723
    I have to ask for support for a problem, I hope to explain the situation well.
    I installed the template on two different servers. I use one as active site and the other as a test site. On the test site I can try extensions or updates before installing them in the active site.
    The template Teline IV is quite complex, so I use the test site also to try the settings for any extensions.
    I usually try updates first on the test site, but the latest update of the template I immediately installed on the active site, but I realized that I had to try it before ….
    In fact, after updating the template the site has stopped working, and the home page appears blank. I checked on the forum andI found the hint to return to the JAT3 previous version framework. I do it and the problem was solved.
    However, still remain a problem. When I open the home page, in the upper left, sometimes appears a numeric string, which disappears only after cleaning the JAT3 cache.
    I wanted to try the rollback of other modules, such as JA News Featured, but it was not possible.
    So I did a check on the test site, and I removed that module and then reinstall the previous version.
    However, after I have installed the previous version I can not activate it.
    If I select a position (sl1-l) set the Modul Class Suffix, set also in which page should be assigned, and than try to save the settings, the saving process does not end correctly, and the settings are not stored.
    Now I have the active site where (sometimes) opening the home page appears some numbers in the left upper corner.
    The test site no longer works correctly, because the JA News Featured module is no longer displayed.
    What can I do?
    I’ve seen that were released new updates of the template, but I’m afraid to install them without having them tested first
    Test site http://www.bikedays.it/cim-fema/
    Active site http://www.cim-fema.it
    Many thanks for any suggestion
    Marco
    Dear Marco,
    PM me admin and FTP account of your test site, I shall try to upgrade the latest version of JAT3 and check what happens in your site.
    Regards.
    cimfema Friend
    #474861
    Ok, for which site? For the test or for the working site?
    Marco
This topic contains 49 replies, has 20 voices, and was last updated by  cimfema 12 years, 2 months ago.
