  • 2377 Friend
    #176074
    Hi, can you help me?? I have a big problem with JA Newspro module (JA teline IV) in frontpage appers:
    31-Mar-2012 04:08:30] PHP Warning: require_once(JPATH_SITEDScomponentsDScom_contentDShelpersDSroute.php) [function.require-once]: failed to open stream: No such file or directory in /home/lagranep/public_html/radiosoh1.com/modules/mod_janewspro/helpers/adapter/content.php on line 4 [31-Mar-2012 04:08:30] PHP Fatal error: require_once() [function.require]: Failed opening required ‘JPATH_SITEDScomponentsDScom_contentDShelpersDSroute.php’ (include_path=’.:/usr/lib/php:/usr/local/lib/php’) in /home/lagranep/public_html/radiosoh1.com/modules/mod_janewspro/helpers/adapter/content.php on line 4 [31-Mar-2012 04:08:31] PHP Warning: require_once(JPATH_SITEDScomponentsDScom_contentDShelpersDSroute.php) [function.require-once]: failed to open stream: No such file or directory in /home/lagranep/public_html/radiosoh1.com/modules/mod_janewspro/helpers/adapter/content.php on line 4 [31-Mar-2012 04:08:31] PHP Fatal error: require_once() [function.require]: Failed opening required ‘JPATH_SITEDScomponentsDScom_contentDShelpersDSroute.php’ (include_path=’.:/usr/lib/php:/usr/local/lib/php’) in /home/lagranep/public_html/radiosoh1.com/modules/mod_janewspro/helpers/adapter/content.php on line 4
    I post an image
    Any idea about this?
    Thank you for your help
    1. a
    Ninja Lead Moderator
    #448711
    I have checked your site, but i saw your site run as well. May be you have fixed it
    2377 Friend
    #448744
    Hi Tamlm, thanks for your support, I fixed it, I uninstal and then re-install the module.
    Thanks.
This topic contains 3 replies, has 2 voices, and was last updated by  2377 12 years, 8 months ago.
