nvestor24 Friend
nvestor24
- March 2012
April 24, 2012 at 2:25 pm #176435dear guys,
i am consfused.
i baught the ja nex temp and the ose membership tool for building a selling-webpage.
the webpage is very extencive and so i need post affiliate pro too.after i have installed the ose membership tool with all the plugins i require…. i still get
an error.[PHP]Warning: Cannot modify header information – headers already sent by (output started at /homepages/xxxxxx/administrator/components/com_osemsc/libraries/PapApi.class.php:5592) in /homepages/xxxxxxx/htdocs/handel/plugins/system/jat3/jat3/core/parameter.php on line 107[/PHP]
by asking the ose team about this problem i get this answer.
<blockquote>Hi Torsten,
The pap need to echo a js script before the page render, and the plugin JA T3 Framework uses setcookie after that action, so it cause the error.
Please try to edit php configuration, set output_buffering to On.
Regards]</blockquote>
I contacted my host for switching output_buffering from “off” to “on” – on the serversite. the customers told me, that i have to do a php.ini with the following code inside:
output_buffering = on
i saved this and put the php.ini file into the root of my joomla-installation. the joomla-version is 2.5.4 – my hoster is 1&1 – the ose membership component is the newest – 5.5.3 – the template is ja nex.
my time is very low….
pleeeeaaasseee i need as fast as possible any help – pleaaasseebest regards
torstenSherlock FriendSherlock
- 2478 times in 2162 posts
April 25, 2012 at 4:48 am #450047Hi torsten,
Have you tried as the ose team mentioned ?
Hi Torsten,
<blockquote>
The pap need to echo a js script before the page render, and the plugin JA T3 Framework uses setcookie after that action, so it cause the error.Please try to edit php configuration, set output_buffering to On.
Regards] </blockquote>
What is the result after doing that ?
nvestor24 Friendnvestor24
- March 2012
April 25, 2012 at 7:46 am #450070good morning dat hoang,
thx for answering.
yes, this is the STATEMENT from the ose team. now, i have putten the php.ini in all directories. the result is, that the error, i upstairs expland dont comes back. but after this, i have the next problem.
IN “IE”, then somebody open the webpage with “cleaned” browsercache – at the first time, the whole webpage is staying by the left side 🙁 :(. if you refresh the the browser (F5), the page went well …. in firefox and safari there is no problem !!!!
regards
April 25, 2012 at 8:13 am #450078Good norming torsten,
That’s a little bit strange, did you try to disable the caching in the template back-end to see if this IE Problem resolves? Also you can post here your url where the issue can be checked.
- March 2012
April 25, 2012 at 11:57 am #450116dear dat,
if you want – i ll send you a pm with the url and login !!!
April 26, 2012 at 4:02 am #450246Hi nvestor24,
I think you can try as following to get rid of the problem on IE
open the file of templates/your_template/css/template.css and adding this css at it’s bottom.wrap {
text-align:center;
.main{
text-align:left;
}That should fix it.
- March 2012
April 26, 2012 at 11:49 am #450316dear dat hoang,
thx for answering.
the bug was fixed by the ose-team. now the nex-template works with ose-membership-controller and post affiliate pro in charm :):):)regards
torsten -
This topic contains 7 replies, has 2 voices, and was last updated by nvestor24 12 years, 7 months ago.
