  • joliver Friend
    #178203
    Issues I’m having with my template
    I’m using the JA Nex quickstart, Joomla 2.5 and would like to use the k2 for commenting on the articles.
    1) K2 – Social Sharing has facebook “Be the first of your friends to like this” spilling into the content. How do I update and change this social plugin?
    2) Why is there only twitter on the front page? Why aren’t the other social “like box” here? Can I have them on all pages?
    3) K2 – Rate this and Author plugins stay active even when disabled? How do I remove these so it is just the article and the comments when viewing the full article?
    4) K2 – How do I make it so the text above the read more isn’t one of the headed fonts? It looks sloppy having it bold and the rest of the content in the standard body copy after clicking the read more..
    5) JA Nex Template- Position “social” and Position “search” in the top right corner aren’t aligned. How to I make them centered or top justified. (This is even the case in the demo)
    Stork11 Friend
    #457952
    <em>@joliver 325639 wrote:</em><blockquote>Issues I’m having with my template
    5) JA Nex Template- Position “social” and Position “search” in the top right corner aren’t aligned. How to I make them centered or top justified. (This is even the case in the demo)</blockquote>
    Hello joliver,
    –> This is K2 core code, so you can’t change.
    –> “Be the first of your friends to like this” is FB like box, and there is a G+ button after it.
    –> You can configure in “Item view options” of K2 category settings.
    –> You can customize “/templates/ja_nex/html/com_k2/templates/nex/item.php” file.
    –> You can do some styles for “topheader” class in “/templates/ja_nex/css/template.css” file.
    Hope this help.
    Best regards.
    gabrielanta Friend
    #464090
    <em>@Stork11 326073 wrote:</em><blockquote>
    </blockquote>
    I´m sure it should be a way to access the K2 code and change the like button to other smaller option.
    Does anyone knows how to do it?
    Thanks and regards,
    Gabriel
    Stork11 Friend
    #464159
    <em>@gabrielanta 334259 wrote:</em><blockquote>Hello,
    Thanks and regards,
    Gabriel</blockquote>
    Hello gabrielanta,
    You can add “data-layout=”button_count”” into Facebook like button code in “/templates/ja_nex/html/com_k2/templates/nex/item.php”.
    change this:
    <div class=”fb-like” data-send=”false” data-width=”200″ data-show-faces=”true”></div>
    to :
    <div class=”fb-like” data-send=”false” data-width=”200″ data-show-faces=”true” data-layout=”button_count”></div>
    Regards.
    omarss79 Friend
    #464887
    By default thw intro text is increase to font-weight:700; font-size: 116% on k2.css
    i commented this part, and the intro take the same size to all articule…
This topic contains 5 replies, has 4 voices, and was last updated by  omarss79 12 years, 3 months ago.
