Could you try again? as I just tried to compile on your site but it worked normally: http://prntscr.com/h4oks8
If you turn the template to development mode to OFF, that is the time responsiveness gets lost, even if you compile less to css. That is what i had said. that is the issue..
Issues still not resolved.
I just turn off the development mode and you can see that it’s showing fine now.
Did you do something other than turn it off. It is working fine. Just wish to know how that came to be. initially it was not working.
Or what is the step-wise procedure
This topic contains 19 replies, has 2 voices, and was last updated by Saguaros 7 years, 1 month ago.
